    Bending a wall around an arc
    13 Posts 6 Posters 1.0k Views 6 Watching
    • P Offline
      paul195
      Hello
      First I should introduce myself...
      I'm Paul from Bristol UK and am new to sketchup as well as this forum. The reason I have gotten into sketchup is that I am trying to make a model of my garden to plan how we are going to modify it. All has been going well so far (i'm sure I am doing things the long winded way at the moment!) but I have run into a problem which I'm hoping for some advice....
      I have modelled a wall to scale which in real life is curved and on different co-planer's, but I drew it in sketchup as a straight wall on the same co-planer thinking (and hoping) that I would be able to bend it into shape afterwards. I have tried to use the Shape bender plugin to try and acheive this but the computer hangs and stops responding when I ask it to do the process (I think the wall may be too complex?). I have also downloaded fredoscale which I haven't yet tried - I thought I'd ask if I have gone about this in the right fashion...should I have modeled the wall curved from the start? Is there anything I can do to bend my wall around the arc?
      I hope I have explained this ok. Any advice would be grately appreciated.
      Thankyou
      • charly2008C Offline
        charly2008
        Hi Paul,
        first you have to weld (weld.rb)the arc.
        Charly
          Paul, could you post the SKP file? That would be a big help.
          You say the wall is diagonal in its bounding box. that could be part of the problem. The other thing is it looks like there's an awful lot of geometry to process so it could just be taking a long time.
          • P Offline
            paul195
            Hi Charly
            Thanks for your reply. I have since downloaded the weld plugin and welded the arc - it gave me the choice to close the curve to which I said no, and then to find faces for the curve to which I said yes. After re-trying to use shape bender the computer again stopped responding - I waited for about five minutes but no joy.
            I have read that I have to be along the red axis - does this mean my wall has to be along the red axis or is it only the straight line that I draw? If the wall has to be along the red axis I'm not sure how to do that - when I select the wall (group) it is diagonally across the selection box as shown in my picture. I have tried to rotate the whole group using the red protractor but cant seem to get it to snap to any of the axis lines.
            I also started to think that it wouldn't process it because it wasn't constructed well enough - I'm sure there are at least a few areas which are not properly lined up - how accurate does the medel need to be connected? I have started to reconstruct the wall but that is gonna take me time which I would prefer not to spend!
            Many thanks
            Paul
            • P Offline
              paul195
              So could somebody clarify for me if the object/group that I am trying to process has to be along the red axis before I start?
              During the course of the evening, I rebuilt the wall to ensure that it was 'well built' and that it was along the red axis line. I tried to process it with shape bender which again stalled the machine - I waited for about ten or fifteen minutes then gave up. Am I waiting long enough? I replaced all the bricks with just plain blocks to test it which worked after about 5 seconds, but I really need to process the wall with the detail included because some lines get lost in the process.
              Getting there slowly!
              Paul
                Clearly then the plugin works.
                Yes, if you expect the wall to wrap properly around the curve, it does need to be aligned with the red axis. That point has been made numerous times throughout the thread. The geometry inside the group or component should be aligned with the red axis but so should its bounding box.
                Since you haven't shared the SKP file there's no way to tell for sure but since the plugin works on a simpler version of the wall, I'm pretty confident in saying you didn't wait long enough.
                It looks like your wall has several repeating patterns and the arc is circular. Why not break the wall down into a smaller unit and bend that? Then just make multiple copies of the bent results to build the rest of the wall.
                  I notice that your wall seems to be made of standardized perforated blocks, cappings etc.
                  In reality you'd build a faceted wall from these, so perhaps ComponentStringer, rather than ShapeBender, would be more appropriate, OR try simply making nested components, placing copies of them and the rotating these around the Z/blue axis - you can easily snap them together and use your curved path as a guide for the rotation of each in turn - like this...Capture.PNG
                  • P Offline
                    paul195
                    Thankyou very much for your help. It worked (in the end) as it turns out that I just wasn't patient enough - it took about an hour to do the whole process in the end! I will also explore the other methods you described TIG.
                    Paul
                    • gillesG Offline
                      gilles
                      You can simply use the rotate tool to make multiple copies, just find the center of the arc.
                        Wy not ? No need to take any aligment along some axis!
                        It's quasi instantaneous! 😉
                        Here 180° but you can take any number of deg !
                          Paul
                          Patience pays off.
                          TIG's method makes the most sense considering in reality you'd get the same result as he shows.
                            That is a good way... but only if it is an arc; if it is another form of curve you will have to place/rotate each vertical-set individually to get the tangents right for each one...
                              And maybe take attention to the deformations of the internal / external forms of the elements
                              for a perfect jonction! 😉
