    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 843.5k Views 121 Watching
    • fredo6F
      fredo6
      1. For planning and adjusting areas of a house (to suit program requirements) - it would be nice to have the option to save a selection of faces, and see how the areas update as you change them in sketchup.
        You have the "areas report" window on ALL THE TIME. You select the faces and components you want once - which gives you the areas. After that you can continue editing the model and the numbers change as you drag lines and change areas - kind of like a set of "entity infos" open all the time for a specific set of pre selected faces. If it cannot be updated "live" you could have an update button (with a keyboard shortcut of course) that would update the info in the box + the different tags.
      This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.
      1. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
      Yes, the plugin counts the real areas within each component, taking into account the scaling factor and shear factor.
      Fredo
      • halroachH
        halroach
        This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.Fredo
        That would be really cool Fredo!
        I'd be glad to contribute with the conceptual design whenever you get around to it. I may have some further ideas as to how this tool could be useful, more effective and easy to use.
        FlexTools - Super Quick Windows, Doors, Slats...
        • fredo6F
          fredo6
          Your comments are welcome. I am not really user of the tool, and it's good to hear from users who have practice and requirement about areas in Sketchup.
          Fredo
          • D
            DesignerPro
            Tried the new curveloft tool set. This is all the errors it generates when I open SketchUp. 😞
            Now WHAT? 😐
            Error Loading File bootstrap_Curviloft.rb
            uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
            uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
            uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
            uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
            uninitialized constant Curviloft::T6Error Loading File FredoTools.rb
            uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb
            undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CountFacesBySides.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CurviShear.rb
            undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__MarkVertices.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RemoveLonelyVertices.rb
            undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReportLabelArea.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RevertCurve.rb
            undefined method register_plug' for FredoTools:ModuleError Loading File __loader.rb undefined method effective_load' for nil:NilClass
            • fredo6F
              fredo6
              @DesignerPro
              This seems to be a problem of installation, probably coming from an erroneous unzip operation.
              The right footprint is indicated in the first post:
              • file LibFredo6.rb
              • Folder LIBFREDO6_Dir_43
              • Folder FREDOTOOLS_Dir_10
              Fredo
              • N
                niks
                thank you very much fredo πŸ‘
                • H
                  hebeijianke
                  thanks fredo
                  chinese language
                  FredoTools_CN.lang
                  • guanjinG
                    guanjin
                    What a powerful tool, too practical, easy language conversion, love you Fredo6
                    I come from China, is to learn
                    • JClementsJ
                      JClements
                      "Show Box Lines" setting for Area Labeler.
                      What does this mean?
                      • fredo6F
                        fredo6
                        When you mouse over or select components, it shows the box of each subcomponents (instead of just showing the faces).
                        Fredo
                        • OxerO
                          Oxer
                          Thanks Fredo!! πŸ‘
                          Spanish Language
                          FredoTools_ES.lang
                          http://www.oxervision.blogspot.com/
                          • fredo6F
                            fredo6
                            @oxer said:
                            Thanks Fredo!! πŸ‘
                            Spanish Language
                            [attachment=0:7r7026d2]<!-- ia0 -->FredoTools_ES.lang<!-- ia0 -->[/attachment:7r7026d2]
                            Oxer,
                            Thanks very much.
                            I just realized that I did not make the Help of VCB and shortcuts translatable. So I'll make it in a next release. This means that there will be some additional strings to translate.
                            Thanks again
                            Fredo
                            • OxerO
                              Oxer
                              There isn't problem Fredo, i'll translate it and thanks again for these incredible tools. πŸ‘
                              • OxerO
                                Oxer
                                I'm testing the FredoTools plugin and i have found some problems:
                                • The arrows keys don't work on Mac.
                                • When you use the first time "Remove Lonely Vertices" and you select "Remove" then if you push the icon "Launch FredoTools plugins from a list" the window of the list don't appears.
                                  For the moment the rest of the features works fine on Mac.
                                • N
                                  notareal
                                  Nice update!
                                  • S
                                    schnydix
                                    Thanks Fredo Nice Work
                                    Need Help Can not Save my new german translation ??
                                    and in 000_AdditionalPluginFolders i got the message:
                                    2ERRORS The Following plugins had errors and may not be fully loaded
                                    Plugin: LMapExt.so
                                    Folder:C/ProgramFiles(x86)Google/GoogleSketchup8/Plugins
                                    ERROR: (eval):1: uninitialized constant
                                    AdditionalPluginFolder6;;LMap
                                    (I Have Not createt an extra Plugin Folder)
                                    and
                                    Plugin: win 32api.so
                                    ERRER: 127
                                    Init_win32api
                                    C/ProgramFiles(x86)Google/GoogleSketchup8/Plugin/win 32api.so
                                    Thanks for help
                                    SU8 on win7
                                    • fredo6F
                                      fredo6
                                      Plugin: LMapExt.so
                                      and
                                      ERRER: 127
                                      Init_win32api
                                      Thanks for help
                                      SU8 on win7
                                      This does not seem related to my scripts.
                                      Maybe some users could tell what is this LmapExt.so file
                                      Fredo
                                        It's associated with LightUp and it should be in the Tools folder
                                        • M
                                          maddesign
                                          I downloaded last FredoTools 1.1 and LibFredo 44, all tools works good except ThruPaint. When i paint by texture(not by colour!) ScetchUp8 crushes! What is a reson of it?
                                          LibFredo6Trace_8_1335077869616.txt
                                          • JClementsJ
                                            JClements
                                            Could "Reverse Faces" be available in the context menu of Thru Paint?
                                            • 23
                                            • 24
                                            • 2 / 24
