    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.5k Views 122 Watching
    • guanjinG
      guanjin
      What a powerful tool, too practical, easy language conversion, love you Fredo6
      • JClementsJ
        JClements
        "Show Box Lines" setting for Area Labeler.
        What does this mean?
        • fredo6F
          When you mouse over or select components, it shows the box of each subcomponents (instead of just showing the faces).
          • OxerO
            Oxer
            Thanks Fredo!! πŸ‘
            Spanish Language
            FredoTools_ES.lang
            • fredo6F
              @oxer said:
              Thanks Fredo!! πŸ‘
              Spanish Language
              [attachment=0:7r7026d2]<!-- ia0 -->FredoTools_ES.lang<!-- ia0 -->[/attachment:7r7026d2]
              Oxer,
              Thanks very much.
              I just realized that I did not make the Help of VCB and shortcuts translatable. So I'll make it in a next release. This means that there will be some additional strings to translate.
              Thanks again
              • OxerO
                Oxer
                There isn't problem Fredo, i'll translate it and thanks again for these incredible tools. πŸ‘
                • OxerO
                  Oxer
                  I'm testing the FredoTools plugin and i have found some problems:
                  • The arrows keys don't work on Mac.
                  • When you use the first time "Remove Lonely Vertices" and you select "Remove" then if you push the icon "Launch FredoTools plugins from a list" the window of the list don't appears.
                    For the moment the rest of the features works fine on Mac.
                  • N
                    notareal
                    Nice update!
                      schnydix
                      Thanks Fredo Nice Work
                      Need Help Can not Save my new german translation ??
                      and in 000_AdditionalPluginFolders i got the message:
                      2ERRORS The Following plugins had errors and may not be fully loaded
                      Plugin: LMapExt.so
                      Folder:C/ProgramFiles(x86)Google/GoogleSketchup8/Plugins
                      ERROR: (eval):1: uninitialized constant
                      AdditionalPluginFolder6;;LMap
                      (I Have Not createt an extra Plugin Folder)
                      and
                      Plugin: win 32api.so
                      ERRER: 127
                      Init_win32api
                      C/ProgramFiles(x86)Google/GoogleSketchup8/Plugin/win 32api.so
                      Thanks for help
                      SU8 on win7
                      • fredo6F
                        Plugin: LMapExt.so
                        and
                        ERRER: 127
                        Init_win32api
                        Thanks for help
                        SU8 on win7
                        This does not seem related to my scripts.
                        Maybe some users could tell what is this LmapExt.so file
                          It's associated with LightUp and it should be in the Tools folder
                            maddesign
                            I downloaded last FredoTools 1.1 and LibFredo 44, all tools works good except ThruPaint. When i paint by texture(not by colour!) ScetchUp8 crushes! What is a reson of it?
                            LibFredo6Trace_8_1335077869616.txt
                            • JClementsJ
                              JClements
                              Could "Reverse Faces" be available in the context menu of Thru Paint?
                              • fredo6F
                                I think this is possible, but the Auto-flip option was there precisely to flip faces on the same side.
                                • fredo6F
                                  Is it reproducible and systematic?
                                  Are you sure this is only with texture, never with color?
                                    rv1974
                                    Fredo why don't you incorporate 'LibFredo' files with 'Fredo tools' pack?
                                    • fredo6F
                                      Simply because LibFredo6 is used by many of my other plugins and that you usually need to have the latest version installed.
                                        rv1974
                                        So incorporate all your stuff (which ~90% is a 'must have') in ONE megapack (with ability to selectively install\uninstall)
                                        Just like another guru does:
                                        http://www.neilblevins.com/cg_tools/soulburnscripts/soulburnscripts.htm
                                          maddesign
                                          Yes, Fredo. This is systematic and this is with textures only. As i put brush with texture to an object, it stay panted by texture,red clocks of waiting appears and program fly out immediately! All other plugins and programmes works properly.
                                          • Didier BurD
                                            Didier Bur
                                            Hi Fredo,
                                            Apart from all my congatulations for this marvelous plugin, just one wish: would it be possible to set the font size used in the dialog boxes and palettes ? (See below)
                                            Best regards,
                                            DB
                                            • 23
                                            • 24
                                            • 2 / 24
