    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.5k Views 122 Watching
      RichardCherry
      Thanks for the nice Christmas present πŸ˜„
      Wonderful set of tools πŸ˜„
      • V
        Vicspa
        Ditto Fredo πŸ‘ πŸ‘ πŸ‘
        • irwanwrI
          irwanwr
          no curviloft? 😞
          • B
            boilingsnow
            Can you tell why I can't load the plugin?
            I have already installed the latest version of LibFredo6.
            • fredo6F
              Can you check the footprint of the files.
              In the Plugins directory, you should have the Folder FREDOTOOLS_Dir_10 with all the files in it.
              It looks like you have the rb files directly in the Plugins directory, not in this folder.
              • B
                boilingsnow
                Thanks for your explanation. It works!
                • halroachH
                  halroach
                  Hi Fredo,
                  very nice plugin!
                  I've been thinking of a similar plugin, which you could incorporate into this one:
                  1. For planning and adjusting areas of a house (to suit program requirements) - it would be nice to have the option to save a selection of faces, and see how the areas update as you change them in sketchup.
                    You have the "areas report" window on ALL THE TIME. You select the faces and components you want once - which gives you the areas. After that you can continue editing the model and the numbers change as you drag lines and change areas - kind of like a set of "entity infos" open all the time for a specific set of pre selected faces. If it cannot be updated "live" you could have an update button (with a keyboard shortcut of course) that would update the info in the box + the different tags.
                  see attached mockup image (numbers are just gibberish for illustration)
                  1. you could have selection sets in pre selected colors for interiors, exteriors etc... kind of like the areas by material, but rather by custom selection.
                  2. you could have sub-totals for faces that were marked together.
                  3. selecting a face or faces in the list will mark them in the model
                  4. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
                  ![live or manually updated "areas report" for pre selected faces](/uploads/imported_attachments/Rgwk_preselectedfaceareas.jpg "live or manually updated "areas report" for pre selected faces")
                  FlexTools - Super Quick Windows, Doors, Slats...
                  • fredo6F
                    This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.
                    1. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
                    Yes, the plugin counts the real areas within each component, taking into account the scaling factor and shear factor.
                    • halroachH
                      halroach
                      This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.Fredo
                      That would be really cool Fredo!
                      I'd be glad to contribute with the conceptual design whenever you get around to it. I may have some further ideas as to how this tool could be useful, more effective and easy to use.
                      • fredo6F
                        Your comments are welcome. I am not really user of the tool, and it's good to hear from users who have practice and requirement about areas in Sketchup.
                          DesignerPro
                          Tried the new curveloft tool set. This is all the errors it generates when I open SketchUp. 😞
                          Now WHAT? 😐
                          Error Loading File bootstrap_Curviloft.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                          uninitialized constant Curviloft::T6Error Loading File FredoTools.rb
                          uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb
                          undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CountFacesBySides.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CurviShear.rb
                          undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__MarkVertices.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RemoveLonelyVertices.rb
                          undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReportLabelArea.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RevertCurve.rb
                          undefined method register_plug' for FredoTools:ModuleError Loading File __loader.rb undefined method effective_load' for nil:NilClass
                          • fredo6F
                            @DesignerPro
                            This seems to be a problem of installation, probably coming from an erroneous unzip operation.
                            The right footprint is indicated in the first post:
                            • file LibFredo6.rb
                            • Folder LIBFREDO6_Dir_43
                            • Folder FREDOTOOLS_Dir_10
                            • N
                              niks
                              thank you very much fredo πŸ‘
                              • H
                                hebeijianke
                                thanks fredo
                                chinese language
                                FredoTools_CN.lang
                                • guanjinG
                                  guanjin
                                  What a powerful tool, too practical, easy language conversion, love you Fredo6
                                  • JClementsJ
                                    JClements
                                    "Show Box Lines" setting for Area Labeler.
                                    What does this mean?
                                    • fredo6F
                                      When you mouse over or select components, it shows the box of each subcomponents (instead of just showing the faces).
                                      • OxerO
                                        Oxer
                                        Thanks Fredo!! πŸ‘
                                        Spanish Language
                                        FredoTools_ES.lang
                                        • fredo6F
                                          @oxer said:
                                          Thanks Fredo!! πŸ‘
                                          Spanish Language
                                          [attachment=0:7r7026d2]<!-- ia0 -->FredoTools_ES.lang<!-- ia0 -->[/attachment:7r7026d2]
                                          Oxer,
                                          Thanks very much.
                                          I just realized that I did not make the Help of VCB and shortcuts translatable. So I'll make it in a next release. This means that there will be some additional strings to translate.
                                          Thanks again
                                          • OxerO
                                            Oxer
                                            There isn't problem Fredo, i'll translate it and thanks again for these incredible tools. πŸ‘
                                            • 23
                                            • 24
                                            • 2 / 24
