    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 836.4k Views 121 Watching
    • H
      hebeijianke
      thanks fredo
      chinese language
      FredoTools_CN.lang
      • guanjinG
        guanjin
        What a powerful tool, too practical, easy language conversion, love you Fredo6
        • JClementsJ
          JClements
          "Show Box Lines" setting for Area Labeler.
          What does this mean?
          • fredo6F
            When you mouse over or select components, it shows the box of each subcomponents (instead of just showing the faces).
            • OxerO
              Oxer
              Thanks Fredo!! πŸ‘
              Spanish Language
              FredoTools_ES.lang
              • fredo6F
                @oxer said:
                Thanks Fredo!! πŸ‘
                Spanish Language
                [attachment=0:7r7026d2]<!-- ia0 -->FredoTools_ES.lang<!-- ia0 -->[/attachment:7r7026d2]
                Oxer,
                Thanks very much.
                I just realized that I did not make the Help of VCB and shortcuts translatable. So I'll make it in a next release. This means that there will be some additional strings to translate.
                Thanks again
                • OxerO
                  Oxer
                  There isn't problem Fredo, i'll translate it and thanks again for these incredible tools. πŸ‘
                  • OxerO
                    Oxer
                    I'm testing the FredoTools plugin and i have found some problems:
                    • The arrows keys don't work on Mac.
                    • When you use the first time "Remove Lonely Vertices" and you select "Remove" then if you push the icon "Launch FredoTools plugins from a list" the window of the list don't appears.
                      For the moment the rest of the features works fine on Mac.
                    • N
                      notareal
                      Nice update!
                        schnydix
                        Thanks Fredo Nice Work
                        Need Help Can not Save my new german translation ??
                        and in 000_AdditionalPluginFolders i got the message:
                        2ERRORS The Following plugins had errors and may not be fully loaded
                        Plugin: LMapExt.so
                        Folder:C/ProgramFiles(x86)Google/GoogleSketchup8/Plugins
                        ERROR: (eval):1: uninitialized constant
                        AdditionalPluginFolder6;;LMap
                        (I Have Not createt an extra Plugin Folder)
                        and
                        Plugin: win 32api.so
                        ERRER: 127
                        Init_win32api
                        C/ProgramFiles(x86)Google/GoogleSketchup8/Plugin/win 32api.so
                        Thanks for help
                        SU8 on win7
                        • fredo6F
                          Plugin: LMapExt.so
                          and
                          ERRER: 127
                          Init_win32api
                          Thanks for help
                          SU8 on win7
                          This does not seem related to my scripts.
                          Maybe some users could tell what is this LmapExt.so file
                            It's associated with LightUp and it should be in the Tools folder
                              maddesign
                              I downloaded last FredoTools 1.1 and LibFredo 44, all tools works good except ThruPaint. When i paint by texture(not by colour!) ScetchUp8 crushes! What is a reson of it?
                              LibFredo6Trace_8_1335077869616.txt
                              • JClementsJ
                                JClements
                                Could "Reverse Faces" be available in the context menu of Thru Paint?
                                • fredo6F
                                  I think this is possible, but the Auto-flip option was there precisely to flip faces on the same side.
                                  • fredo6F
                                    Is it reproducible and systematic?
                                    Are you sure this is only with texture, never with color?
                                      rv1974
                                      Fredo why don't you incorporate 'LibFredo' files with 'Fredo tools' pack?
                                      • fredo6F
                                        Simply because LibFredo6 is used by many of my other plugins and that you usually need to have the latest version installed.
                                          rv1974
                                          So incorporate all your stuff (which ~90% is a 'must have') in ONE megapack (with ability to selectively install\uninstall)
                                          Just like another guru does:
                                          http://www.neilblevins.com/cg_tools/soulburnscripts/soulburnscripts.htm
                                            maddesign
                                            Yes, Fredo. This is systematic and this is with textures only. As i put brush with texture to an object, it stay panted by texture,red clocks of waiting appears and program fly out immediately! All other plugins and programmes works properly.
                                            • 23
                                            • 24
                                            • 2 / 24
