    TexFresnel Explanation?
    renderpluginsextensions
    7 Posts 3 Posters 4.1k Views 3 Watching
    • peter_shawP Offline
      peter_shaw
      Hello everyone!
      Can someone explain how TexFresnel works? I googled and found this http://www.vray.com/vray_for_sketchup/manual/refraction_layer.shtml but it seems outdated.
      I use TexFresnel as reflection map and i know what the IOR does, i even found a list of IOR values for different materials, but what about Refract IOR and the other variables?
      • majidM Offline
        majid
        please see the attached file
        fresnel.skp
          peter_shaw
          thanks a lot for the explanation majid! but i can't render your skp file 😞 the materials list in vray is empty. maybe because we use different vray versions? i have 1.48.89.
          but your idea is really good: im just gonna run some tests myself with 20 different cylinders and see how different values behave.
          edit: ok, here's the results if anyone is interested. wanted to test more (multiplier by exponent?, texFresnel on refraction map slot?) but got lazy...
          fresnel.pdf
            @peter_shaw said:
            i have 1.48.89.
            Update to the latest version, currently 1.49.01. Many bugs are fixed since your version. Always check if your software is up to date.
            • majidM Offline
              majid
              no need to change the IOR for refraction, as there is no refraction in your scene. BTW seems you are now ok by experiencing πŸ˜‰
              my KT tutorial also contains the fresnel explanation...(http://www.sketchupartists.org/tutorials/sketchup-and-kerkythea/kerkythea-take-a-deeper-look-at-materials/)
                peter_shaw
                yes thanks again i think experimenting is the best anyways - learning by doing.
                  peter_shaw
                  @thomthom said:
                  @peter_shaw said:
                  i have 1.48.89.
                  thanks for the heads up. just updated to 1.49.01. wow, didnt think they updated that much in a 0.0012 version jump πŸ˜„
                  even the UI is all cleaned up and nice πŸ˜„
