    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 85.3k Views 43 Watching
    • sumasterS Offline
      sumaster
      Hello tak2hata,
      It's very useful tool .......
      GooD ....... Thank you ........
      Very nice .......
      Thank you,
      SUmaster
      • simon le bonS Offline
        simon le bon
        Hi tak2hata β˜€
        This is a very smart tool where Su is lacking. Thanks a lot. πŸ‘ πŸ‘ 😎
        (not very far from TIG's "Hole Punching Tool" complementary and maybe more easy to use "on the fly".
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_01.jpg
        Do you think It will be possible to overpass some limitations ?
        -> use it on a shape which is not necessarily : - a closed shape, - a group or a component.
        -> select a bunch of faces to be hole punched rather than to be one by one ?
        My respect and my friendship for what you gracefully share into this place,
        http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/applause.gif
        ++simon
          tak2hata
          I update this to v1.6.in Dec 14, 2011.
          New function and small improves.
          Enjoy. πŸ˜‰
          by TAK2HATA
            RichardCherry
            Absolutely superb!
            The update is excellent, thank you πŸ˜„
            • bmikeB Offline
              bmike
              will try it out after the update!
              mike beganyi design + consulting llc
                simon le bon
                Dear tak2hata,
                veryyy nice upgrade indeed!! πŸ‘ πŸ‘ πŸ˜„
                (model Fancy arched window by loverevolutionary on 3D Warehouse)
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_002.jpg
                Would you please tak2hata not give up in such a good path: It remains a major limitation.
                It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_003.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_004.jpg
                A little reminder on how make a Component with a cutting option:
                (I have myself to revisit the process each time πŸ˜• )
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_005.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_006.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_007.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_008.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_009.jpg
                Cheers,
                simon
                  tak2hata
                  Hi,Simon.
                  Thanks your opinion.
                  I will add function multi hole.
                  You give me nice idea and description picture.
                  And the funcy window is very nice.
                  Thanks.
                  by TAK2HATA
                    sicd_steve
                    It won't work on Snow Leopard 10.6.8 I can't get it to work on a Mac?
                    I have done everything ?
                      jorge2011
                      tak2hata hello. Thank you very much for this excellent plugin.
                      Just a suggestion,
                      Is possible to add an option (for example by pressing the alt key) for projecting the selected faces over the group or component?
                        It does something on my Mac with 10.6.8. It's not what I expected. Hmmm
                          tak2hata
                          Hi,sicd_steve ,Dave.
                          I will test the problem on mac later in few days.
                          Please wait.
                          by TAK2HATA
                            driven
                            Hi it's working, with and without other plugins enabled on 10.5.8.
                            I do get
                            WARNING: make_unique is a deprecated methodof Sketchup:Group nil WARNING: make_unique is a deprecated methodof Sketchup:Group
                            but it functions.
                            so any one on Lion who is up for a simple test can.
                            in 'Ruby Console' enter
                            Sketchup.plugins_disabled = **true**
                            then quit and restart, you will now not have a plugins menu,
                            so open Ruby Console again and type or copy/paste
                            load '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/create_hole_on_solid.rb'
                            modify if your path is different
                            Retest the plugin... then into RC again
                            Sketchup.plugins_disabled = **false**
                            to turn back on all your plugins next startup.
                            john
                              tak2hata
                              I test this plugin on mac os 10.6.8 and sketchup v8 free.
                              It work well.
                              So I need to know what is caused for this problem.
                              Please show the ruby console message as Driven says.
                              I will guess from that message.
                              Thanks.
                              by TAK2HATA
                                Here you go.
                                nil
                                Error: #<TypeError: Cannot convert argument to Sketchup::Entities>
                                /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in intersect_with' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in subtract_form'
                                /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:139:in subtract_form_MS' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:131:in subtract_start'
                                /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:440:in increment_state' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:470:in onLButtonDown'
                                  tak2hata
                                  Hi,Dave:
                                  I update this plugin.
                                  This will work.
                                  Sorry this problem was happened in windows os ,too. but It was corrected.
                                  Please try it.
                                  Thanks.
                                  by TAK2HATA
                                    Excellent! It work well now. Thank you.
                                    May I make a request? I know you changed the script so that when a circle is punch through, the edges on the sides of the hole are soften. That's the way I think it should work but... For polygons, could you make it so that the edges are not softened?
                                      samatall
                                      Hi tak2hata,
                                      I tried it in SU 8. I did a simple wall and a circle face in front of it. Then I applied this plugin. It only duplicated the circle (but grouped). I tried using window components on it. It also made a intersection profiled face on the wall. I have no idea how to figure out this. Can anyone help?
                                        Post the example SKP file so it can be examined.
                                          samatall
                                          Dave, Attached is the model to explain it. Thanksexample001.skp
                                            I opened the wall group and deleted the copy of the circle. Then I closed the group. I selected the tool, the wall and then the circle. Hole punched just fine. Do you have the most recent version of the plugin?
                                            example001.skp
                                            • 6
                                            • 7
                                            • 3 / 7
