    Problem rendering animation
    renderpluginsextensions
    16 Posts 12 Posters 7.9k Views 12 Watching
      jwktje
      Hi everyone,
      I have a problem I hope you can help me with.
      I used the Proper Animation to rotate a sphere. I want to render these scenes into an animation with the Vray renderer.
      Vray for sketchup can render scene animation but it doesn't seem to take the object rotation into account.
      I can't change renderer because i need to use my Vray material wich has a displacement map assigned.
      I'm stuck, is there a way to do this with vray for sketchup? Even if i need to do it frame by frame.
      Any help is appreciated.
      Cheers, Jwktje
      • boofredlayB Offline
        boofredlay
        Oma, I moved your question to the Vray section. You will probably get a quicker response.
        • P Offline
          pepa
          Proper animation with vray not working for me.. but I saw video on youtube: http://www.youtube.com/watch?v=XzvLSSvuU-4 it would be inspirated, how to create animation in SU and Vray..cheers
          http://jsvizualizace.daportfolio.com/
          • V Offline
            valerostudio
            My understanding is that these rotating/moving object scripts use layers to make objects 'move'. I don't think the current version of VfSU takes layers into consideration when rendering an animation. This is somethign hopefully that gets addressed in the new version slated to come out very soon.
            • dkendigD Offline
              dkendig
              correct, we don't pay attention to layer visibility changes in the current version.
              Devin Kendig
              Developer
                rspierenburg
                Rather than animating the sphere rotating is it at all possible to keep the sphere static and animate the camera around it, thus making the illusion that the sphere is rotating? Or is there more than just a sphere in the scene? Just a thought
                  jcesarbio
                  I was able to render the proper animation with vray... But I had to trick que program to do so.. When you download the plugin it cames with two samples, one of them is named Boxes 2. I tried movie render this and the man on the scene was moving on the movie (yey!!) but not the boxes =(... (you must have the "Start Scene Observer" on) I couldn´t find why the boxes didn´t move, so a copied the man, made unique, copied something else in the component. It worked... I deleted me man.. still working.... So I´ll try now to do something bigger... when I get the results I´ll post here.. I just wanted to share this so maybe someone could explore this feature, since it kind of proved to be able to render animations... I may get interesting...
                  • andybotA Offline
                    andybot
                    WOW, with vray!? please do post an example. I thought things were fixed in vray (i.e. first scene state is the only one rendered.)
                    Edit: too good to be true. I tried a few tests, no dice.
                      jcesarbio
                      UPDATE: SUCCESSFUL ANIMATION RENDER.
                      Well, I found out the diference between the man and the boxes (only the man was animating - view my previous post).
                      The man is a facing camera component.
                      Sooooo..
                      If you make a component, and set this to always face camera, it will render the object animation on vray.
                      There is a problem with that... I can´t properly place my objets if they are always facing camera... Any ideas???
                      JC
                        jcesarbio
                        A very simple test I made.. http://www.youtube.com/watch?v=bFY5JrXmPKU
                        • andybotA Offline
                          andybot
                          interesting, so those are all face me components with different component centers?
                            adebeo
                            I transform my componant into a faceme componant
                            I export animation from Vray but it always render the same image, ....
                            My very very insterresting by your test, please go on, ...
                            adebeo
                            Nos Formations sketchup
                            Notre blog : www .adebeo.com/wp/
                            Nos tutoriels: www .youtube.com/adebeo
                              linctus
                              Now it's 2014, and VRay 2.0 is working good! But I still can't see layer or hiden settings in scene transactions when rendering animation. Maybe need enable some options?
                              • TedVitale_CGT Offline
                                TedVitale_CG
                                We still don't pay attention to layer visibility changes in the current version of V-Ray animation tools. We have however provided the ability to use the Batch render tool which renders each scene in the Scene tab menu and recognizes the changes between each. This is useful if you are doing a frame by frame animation utilizing the scene manager in Sketchup.
                                Ted Vitale
                                Owner | Creative Director
                                http://www.voxl.vision
                                  mattgatlin
                                  Ted,
                                  So can you animated moving components at all using V-Ray for Sketchup?
                                  edit:
                                  I've achieved a simple animation using keyframe and then just batch rendering the scenes together with animation turned off in the v-ray options.
                                  Recognizing layer visibility in animation should be pretty high on the list of updates to the next v-ray
                                    TedVitale_CG
                                    Layer visibility during batch rendering is supported, so if you set up a key frame animation using a third party plugin, you then have the ability to animate moving components. Batch rendering was not set up with this in mind, but if you can get the work flow figured out, I'm sure its possible.
                                    Recognizing layer visibility in animation is on the list, and may be a possibility in the future, but that means re-parcing a scene for ever frame. That adds a lot of time with larger animated models.
                                    Ted Vitale
