    Texture/Picture Slippage
    15 Posts 5 Posters 921 Views 5 Watching
    • MarianM
      Marian
      Has anyone encountered this problem ? I've noticed it before but only now is it really annoying. When I zoom in towards a textured face/imported image in SU the image just jumps and deforms. I've only encountered it in SU8 and the problem doesn't appear when you export a 2d image.
      Problem in viewport, but all fine on export.
      Print screen of problem.
      • TIGT
        Are these images 'real size' ?
        Very small or very large images might distort...
        Have you tried adjusting the Preferences > OpenGL settings to see if it improves the display ?
        • thomthomT
          Never seen that. Does it happen if you disable Hardware Acceleration?
          • MarianM
            Marian
            Yeah they are mostly ,+/- a little scale, the same size at which SU imported them and the length of the picture 6m+.
            Ok so I tried the settings, If I disable hardware accelaration the image dispappears instead of deforming but I now checked "use maximum texture size" and seems to be ok however much I zoom.
            Thanks TIG, didn't think that would solve it.
            • thomthomT
              Sounds like a graphic card issue. Drivers up to date? What card do you have?
              • MarianM
                Marian
                I have a 4 year old ATI x1550 and did install the latest driver but even that seems to bee little old. I also have an issue with Simlab Composer now after I installed the drivers. The preview of the hdri image is all jumbled up but used to work just fine before. I posted that on their forum no solution as of yet.
                I think it's I time I consider buying a new card but really good ones are expensive and not sure if they are compatible with my motherboard.
                • MarianM
                  Marian
                  The problem is back even with the maximum texture size checked 😞
                  • thomthomT
                    Can you post the model? So we can test on our system?
                    • MarianM
                      Marian
                      Sure here it is.
                      Another odd behaviour I observed is that when I select the textured surfaces the deforming goes away, but after I select something else bang there it is. πŸ˜›
                      Sam Loovers saloon.skp
                        I didn't experience any slippage when zooming/orbitting or changing perspective
                        • TIGT
                          No issues for me.
                          • thomthomT
                            Nor do I.
                            This is a graphic card/driver issue.
                            • MarianM
                              Marian
                              Drat.
                              • brodieB
                                brodie
                                I don't have a fix for you but I have encountered that before although it's quite rare. I don't believe I found a solution. I know I tried exploding the component it was in and that sort of thing but I think sometimes it helped and sometimes not. Fortunately for me it wasn't crucial that the texture didn't move.
                                -Brodie
                                • MarianM
                                  Marian
                                  Yeah it's an on and off problem. If I go and check uncheck stuff in preferences it works a while than it appears again.
