    Edges disappearing in model
    8 Posts 4 Posters 3.3k Views 4 Watching
      skeerc
      Hi, I'm having the black edges intermittently disappear in SKP model, not all edges just some, although the connected faces are still present & showing. Have tried "save" & re-open but the models remains the same. Using SKP pro 8 (latest update) on Mac Pro 3,1 OSX 10.6.8. Does anyone have any suggested fixes or ideas regarding this. "Snapping" to corners etc becomes quite tedious. Cheers
      • hellnbakH Offline
        hellnbak
        It would be easier to see what's going on if you could post the model.
          skeerc
          Hi, This screen shot has edges, edges missing & a selected face, Thanks
            Looks like they are hidden. What is you turn on Hidden Geometry?
            Sample model?
              skeerc
              Turning On & Off Hidden Geometry has no effect, but have noticed turning On & Off certain Groups does make a difference - in the attachment a Roof Group was turned off. There seems to be no link between the groups that I can find & have tried exploding a group & re-grouping but it remains the same, it still will effect another group when turned off (ie:some edges in another group will disappear).Thanks
                Can you post a sample model? It'd make it a lot easier to debug this.
                  It looks like you have put some of your geometry, like 'edges' on a layer that's 'OFF'.
                  You can't then see it BUT it is still linked to other geometry on 'ON' layers.
                  Ensure all 'raw' edges/faces are on Layer0.
                  Edit the container and select all and use Entity Info to revert the layers to Layer0...
                  [There is a Plugin to do this if you have loads of them to fix...]
                  Always have Layer0 as the current layer, and have it 'ON'.
                  Only place Groups/Component-Instances on other layers and then use ON/OFF for those to control the visibility of the now well layered objects.
                  Layering your raw geometry is a guaranteed path to madness... as you have found!
                    skeerc
                    Thanks for the input - Have solved the issue by eg: Walls - edit>select all & placing them back on their original Layer via Entity Info which has worked! Layer0 had remained On all the time as I always group & create separate Layers via Entity Info as I work, so not sure what happened but the wheels are back on!!!!
