    UV mapping trouble
    22 Posts 4 Posters 2.3k Views 4 Watching
    • EdsonE
      Edson
      I am having problems with a texture that I want to run vertically on the bottom of the wall and horizontally on the top. I have used thom's UV toolkit to rotate the texture but the rendered result is always bad. I use podium for the renders. I would appreciate any help.
      http://www.mahfuz.arq.br
        Does Podium need that face triangulated or does it triangulate on export?
        Can you upload that wall rather than sharing the whole scene?
        I notice the leather chair has funky mapping also.
        • EdsonE
          Edson
          as far as I know, podium does not need any triangulation. model attached.
          texture_problem.skp
          • soloS
            solo
            Edson,
            Just right click and reset texture, then re apply as per what you need, using rotation 90 degrees.
            http://www.solos-art.com
            • EdsonE
              Edson
              @solo said:
              Edson,
              pete,
              reset is greyed out. how can I do it then?
              • soloS
                solo
                It was not greyed out on my side....that's wierd.
                  There's strange things happening with that chair too?
                  I was remapping it and every-time I edit it the textures jumble. I fix them exit and if I edit again they rejumble.
                  Materials have been applied to back faces on both the wall and the chair. I'm not sure if this affects Podium though?
                  Looking at that screenshot you can see that some sort of planar subdivision has been applied to the textures.
                  • PixeroP
                    Pixero
                    You could try my UVprojection script: http://forums.sketchucation.com/viewtopic.php?f=323&t=34552
                    • EdsonE
                      Edson
                      ajn,
                      thanks for the tip: i did not know your plugin. 😳 however, I surely do not know how to apply it as I am getting no results. I even tried it on a bed spread but nothing changes. for one, I do not understand the issue of choosing an axis for faces that are at an angle to the axes. can you tell me how to apply UV Projection? I am afraid the topic on it is not explanatory enough.
                      texture_problem 2011-08-27 08190300000.pngScreen shot 2011-08-27 at 8.24.52 AM.png
                      • PixeroP
                        Pixero
                        It does planar projection in X, Y or Z axis so for things like your wall it "should" work.
                        The faces need a texture before applying the UV projection. Choose the axis that is perpendicular to the faces normal.
                        So for a wall it should be either X or Y.
                        Size and such is just fine tuning so I won't go in to details here.
                        The bedspread would need UV unwrapping to map correctly but at least it should look like one continous map with stretching in the parts that doesn't align to the projected axis. Could you share the bedspread and the wall scene so I can see if there is something wrong with the script or just how you use it?
                          Edson,
                          Did you change the pin positions on those textures? If you right click and choose position what happens?
                          • EdsonE
                            Edson
                            the wall model had already benn posted above. here it goes again with the bedspread. you will see that I changed the texture but the problem remains the same.
                            texture_problem_2.skp
                            • EdsonE
                              Edson
                              Edson,
                              all I did was to rotate the texture without scaling it.
                              • EdsonE
                                Edson
                                I had to throw that wall away and model it again. no solution worked. thanks, anyway. I learned some more about UV mapping because of this problem.PV_3_16AGO_render 2011-08-27 18411600000 copy.jpg
                                  Here's a mapped bedsheet that only needs the material replaced via Entity Info to keep mapping
                                  Bedsheet_Mapped.skp
                                  • EdsonE
                                    Edson
                                    [attachment=1:1bw55jfn]<!-- ia1 -->Edson_Bedsheet.jpg<!-- ia1 -->[/attachment:1bw55jfn]
                                    [attachment=0:1bw55jfn]<!-- ia0 -->Bedsheet_Mapped.skp<!-- ia0 -->[/attachment:1bw55jfn]
                                    thanks, rich. could you tell me how you did it? which tool was involved? as people say : it is nice to be given the fish but it is much nicer to be taught how to fish it.
                                      I'm using Whaat's UV Tools v0.2 to export the UVs as an .obj file. Then in UV Layout 2 I map the texture and save. In SU I reimport the .obj UV map. This then applies the mapping to the normally skewed textures. here's a video I did awhile back showing the workflow between SU and UV LayOut
                                      [flash=800,600:3dh8q0qe]http://www.youtube.com/v/_HdqT_SGbek[/flash:3dh8q0qe]
                                      • PixeroP
                                        Pixero
                                        Here is the scene with UVs projected. The bedspread would naturally look better with UVs unwrapped to avoid streching. Also made a copy with separate projections for the sides. That looks a little better but shows a seam where the projections meet. Does the wall look correct in render now?
                                        texture_problem_2b.skp
                                        • EdsonE
                                          Edson
                                          thanks, jan. yes, the wall looks correct now that I remodeled it. I just could not fix the problem related here.PV_3_16AGO_render 2011-08-27 18411600000 copy.jpg
                                          • EdsonE
                                            Edson
                                            a very informative video, rich. I have saved the name of the app for future needs.
                                            • 1 / 2
