    UV mapping trouble
    22 Posts 4 Posters 2.4k Views 4 Watching
    • PixeroP
      Pixero
      You could try my UVprojection script: http://forums.sketchucation.com/viewtopic.php?f=323&t=34552
      • EdsonE
        Edson
        ajn,
        thanks for the tip: i did not know your plugin. 😳 however, I surely do not know how to apply it as I am getting no results. I even tried it on a bed spread but nothing changes. for one, I do not understand the issue of choosing an axis for faces that are at an angle to the axes. can you tell me how to apply UV Projection? I am afraid the topic on it is not explanatory enough.
        texture_problem 2011-08-27 08190300000.pngScreen shot 2011-08-27 at 8.24.52 AM.png
        http://www.mahfuz.arq.br
        • PixeroP
          Pixero
          It does planar projection in X, Y or Z axis so for things like your wall it "should" work.
          The faces need a texture before applying the UV projection. Choose the axis that is perpendicular to the faces normal.
          So for a wall it should be either X or Y.
          Size and such is just fine tuning so I won't go in to details here.
          The bedspread would need UV unwrapping to map correctly but at least it should look like one continous map with stretching in the parts that doesn't align to the projected axis. Could you share the bedspread and the wall scene so I can see if there is something wrong with the script or just how you use it?
            Edson,
            Did you change the pin positions on those textures? If you right click and choose position what happens?
            • EdsonE
              Edson
              the wall model had already benn posted above. here it goes again with the bedspread. you will see that I changed the texture but the problem remains the same.
              texture_problem_2.skp
              • EdsonE
                Edson
                Edson,
                all I did was to rotate the texture without scaling it.
                • EdsonE
                  Edson
                  I had to throw that wall away and model it again. no solution worked. thanks, anyway. I learned some more about UV mapping because of this problem.PV_3_16AGO_render 2011-08-27 18411600000 copy.jpg
                    Here's a mapped bedsheet that only needs the material replaced via Entity Info to keep mapping
                    Bedsheet_Mapped.skp
                    • EdsonE
                      Edson
                      [attachment=1:1bw55jfn]<!-- ia1 -->Edson_Bedsheet.jpg<!-- ia1 -->[/attachment:1bw55jfn]
                      [attachment=0:1bw55jfn]<!-- ia0 -->Bedsheet_Mapped.skp<!-- ia0 -->[/attachment:1bw55jfn]
                      thanks, rich. could you tell me how you did it? which tool was involved? as people say : it is nice to be given the fish but it is much nicer to be taught how to fish it.
                        I'm using Whaat's UV Tools v0.2 to export the UVs as an .obj file. Then in UV Layout 2 I map the texture and save. In SU I reimport the .obj UV map. This then applies the mapping to the normally skewed textures. here's a video I did awhile back showing the workflow between SU and UV LayOut
                        [flash=800,600:3dh8q0qe]http://www.youtube.com/v/_HdqT_SGbek[/flash:3dh8q0qe]
                        • PixeroP
                          Pixero
                          Here is the scene with UVs projected. The bedspread would naturally look better with UVs unwrapped to avoid streching. Also made a copy with separate projections for the sides. That looks a little better but shows a seam where the projections meet. Does the wall look correct in render now?
                          texture_problem_2b.skp
                          • EdsonE
                            Edson
                            thanks, jan. yes, the wall looks correct now that I remodeled it. I just could not fix the problem related here.PV_3_16AGO_render 2011-08-27 18411600000 copy.jpg
                            • EdsonE
                              Edson
                              a very informative video, rich. I have saved the name of the app for future needs.
                              • EdsonE
                                Edson
                                there is a very good tutorial on the use of UVProjection in conjunction with Artisan:
                                Sketchup Projection Painting - YouTube
                                by AprC8Life
                                • PixeroP
                                  Pixero
                                  Sweet. I haven't seen it before.
                                  Thanks for the link.
