    UV mapping trouble
    22 Posts 4 Posters 1.4k Views 4 Watching
    • PixeroP Offline
      Pixero
      It does planar projection in X, Y or Z axis so for things like your wall it "should" work.
      The faces need a texture before applying the UV projection. Choose the axis that is perpendicular to the faces normal.
      So for a wall it should be either X or Y.
      Size and such is just fine tuning so I won't go in to details here.
      The bedspread would need UV unwrapping to map correctly but at least it should look like one continous map with stretching in the parts that doesn't align to the projected axis. Could you share the bedspread and the wall scene so I can see if there is something wrong with the script or just how you use it?
        Edson,
        Did you change the pin positions on those textures? If you right click and choose position what happens?
        • EdsonE Offline
          Edson
          the wall model had already benn posted above. here it goes again with the bedspread. you will see that I changed the texture but the problem remains the same.
          texture_problem_2.skp
          http://www.mahfuz.arq.br
          • EdsonE Offline
            Edson
            Edson,
            all I did was to rotate the texture without scaling it.
            • EdsonE Offline
              Edson
              I had to throw that wall away and model it again. no solution worked. thanks, anyway. I learned some more about UV mapping because of this problem.PV_3_16AGO_render 2011-08-27 18411600000 copy.jpg
                Here's a mapped bedsheet that only needs the material replaced via Entity Info to keep mapping
                Bedsheet_Mapped.skp
                • EdsonE Offline
                  Edson
                  [attachment=1:1bw55jfn]<!-- ia1 -->Edson_Bedsheet.jpg<!-- ia1 -->[/attachment:1bw55jfn]
                  [attachment=0:1bw55jfn]<!-- ia0 -->Bedsheet_Mapped.skp<!-- ia0 -->[/attachment:1bw55jfn]
                  thanks, rich. could you tell me how you did it? which tool was involved? as people say : it is nice to be given the fish but it is much nicer to be taught how to fish it.
                    I'm using Whaat's UV Tools v0.2 to export the UVs as an .obj file. Then in UV Layout 2 I map the texture and save. In SU I reimport the .obj UV map. This then applies the mapping to the normally skewed textures. here's a video I did awhile back showing the workflow between SU and UV LayOut
                    [flash=800,600:3dh8q0qe]http://www.youtube.com/v/_HdqT_SGbek[/flash:3dh8q0qe]
                    • PixeroP Offline
                      Pixero
                      Here is the scene with UVs projected. The bedspread would naturally look better with UVs unwrapped to avoid streching. Also made a copy with separate projections for the sides. That looks a little better but shows a seam where the projections meet. Does the wall look correct in render now?
                      texture_problem_2b.skp
                      • EdsonE Offline
                        Edson
                        thanks, jan. yes, the wall looks correct now that I remodeled it. I just could not fix the problem related here.PV_3_16AGO_render 2011-08-27 18411600000 copy.jpg
                        • EdsonE Offline
                          Edson
                          a very informative video, rich. I have saved the name of the app for future needs.
                          • EdsonE Offline
                            Edson
                            @pixero said:
                            You could try my UVprojection script: http://forums.sketchucation.com/viewtopic.php?f=323&t=34552
                            there is a very good tutorial on the use of UVProjection in conjunction with Artisan:
                            Sketchup Projection Painting - YouTube
                            by AprC8Life
                            • PixeroP Offline
                              Pixero
                              Sweet. I haven't seen it before.
                              Thanks for the link.
