    Lock Guides?
    12 Posts 7 Posters 3.7k Views 7 Watching
    • JClementsJ Offline
      JClements
      Can this be done via ruby?
      I am making some templates and I'd like to keep from having the guides moved by accident. ❓
        Group the lines and lock the group.
        BUT if you 'delete guides' from the menu they'll erase - they can't be locked completely!
          JClements
          Thanks, TIG.
          Perhaps Locking Guidelines would be something to request for SU9.
          • utilerU Offline
            utiler
            @jclements said:
            Thanks, TIG.
            Along with customizing guidelines, period. [line styles, etc]
            Just Curious...
              You can make customized style guide-lines in Ruby code - there are a number of dash/dot patterns. So you could make a menu item for dashed, dotted, center guides etc...
              Or you could have a context-menu to change selected guides' style.
              You can also set their color BUT this is global for all guides.
              I think that the easy global deletion of guides is a real issue as those within components or groups even if they are locked will go, perhaps unexpectedly...
                Plugin: Construction Line Tool
                The Construction Line Tool allows you to draw constructions lines in a similar way as the Pencil Tool. Toolbar: View > Toolbars > Const...
                (sketchuptips.blogspot.com)
                • gullfoG Offline
                  gullfo
                  best to use the clinetool, TIG's context guide tool, and the xline2line.rb and xlines.rb plugins. i actually never knew there was a dedicated edit menu command to delete guides 😲 since i never really ever wholesale delete them, usually have them in groups and layers as needed.
                  Glenn
                  http://www.runnel.com
                  • utilerU Offline
                    utiler
                    @ TT, I use Jim's construction line tool daily... πŸ‘
                    @ TIG, thanks for the heads up; if only i had the time to get into Ruby.... 😞 😞 😞 thanks for the info though! πŸ‘
                    Just Curious...
                      See here for a simple 'ClineStyler' http://forums.sketchucation.com/viewtopic.php?p=349790#p349790
                      • utilerU Offline
                        utiler
                        you never cease to amazing, TIG..... 😍
                        Just Curious...
                        • E Offline
                          eddiegordo23
                          Select the guides you want to lock the click edit and lock.
                          • fredo6F Offline
                            fredo6
                            Unfortunately, Guide Lines and Guide Points cannot be locked in the user interface and not even with the API.
