    Lock Guides?
    12 Posts 7 Posters 3.9k Views 7 Watching
    • JClementsJ
      JClements
      Thanks, TIG.
      Perhaps Locking Guidelines would be something to request for SU9.
      • utilerU
        utiler
        @jclements said:
        Thanks, TIG.
        Along with customizing guidelines, period. [line styles, etc]
        Just Curious...
          You can make customized style guide-lines in Ruby code - there are a number of dash/dot patterns. So you could make a menu item for dashed, dotted, center guides etc...
          Or you could have a context-menu to change selected guides' style.
          You can also set their color BUT this is global for all guides.
          I think that the easy global deletion of guides is a real issue as those within components or groups even if they are locked will go, perhaps unexpectedly...
            Error 404 (Not Found)!!1
            (sketchuptips.blogspot.com)
            • gullfoG
              gullfo
              best to use the clinetool, TIG's context guide tool, and the xline2line.rb and xlines.rb plugins. i actually never knew there was a dedicated edit menu command to delete guides 😲 since i never really ever wholesale delete them, usually have them in groups and layers as needed.
              Glenn
              http://www.runnel.com
              • utilerU
                utiler
                @ TT, I use Jim's construction line tool daily... πŸ‘
                @ TIG, thanks for the heads up; if only i had the time to get into Ruby.... 😞 😞 😞 thanks for the info though! πŸ‘
                Just Curious...
                  See here for a simple 'ClineStyler' http://forums.sketchucation.com/viewtopic.php?p=349790#p349790
                  • utilerU
                    utiler
                    you never cease to amazing, TIG..... 😍
                    Just Curious...
                    • E
                      eddiegordo23
                      Select the guides you want to lock the click edit and lock.
                      • fredo6F
                        Unfortunately, Guide Lines and Guide Points cannot be locked in the user interface and not even with the API.
