    [Plugin] QuadFaceTools
    680 Posts 116 Posters 550.6k Views 116 Watching
      View > Hidden Geometry > OFF
      THEN paint surface ?
      • K Offline
        Kristusea
        That's not the point! I know how to turn off hidden edges.
        What i'm saying is when i select the UV Mapping Tool i can only select one axes.
        The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
          Can you post the problem SKP, so we can look at it ?
          • jo-keJ Offline
            jo-ke
            I am using this plugin to texture a special curtain model.
            I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
            I've downloaded the latest version.
            did I do something wrong?
            http://www.zz7.de
            • KrisidiousK Offline
              Krisidious
              Works for me... Maybe you need TT's new library?
              By: Kristoff Rand
              • jo-keJ Offline
                jo-ke
                Is also installed the latest version with su2015. I'll post both files here....
                http://www.zz7.de
                • jo-keJ Offline
                  jo-ke
                  here is the comparison
                  http://www.zz7.de
                  • jo-keJ Offline
                    jo-ke
                    here are the files
                    su7 works
                    su2015 doesn't work
                    quad-su2015.skp
                    quad-su7.zip
                    http://www.zz7.de
                      If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                      Also, can you describe the steps you perform in more detail?
                      • jo-keJ Offline
                        jo-ke
                        when I start the uv mapper in version 2015 it doesn't show the horizontal and the vertical line to set the direction of the texture. so I can't use it.
                        http://www.zz7.de
                        • jo-keJ Offline
                          jo-ke
                          it seems to be that the model in version SU7 is quad face and when I import it to SU2015 it is a sandbox mesh.
                          I converted it again to quadface and the UV texture mapper worked.
                          everything fine!
                          http://www.zz7.de
                            Did you remember to convert the Sandbox Tool mesh into a QuadFace Tools compatible mesh first?
                            • jo-keJ Offline
                              jo-ke
                              Yes. I've did it like that and saved the component as SU7 some years ago and used it many times, just using the UV Mapper.
                              But now, when I import the same component to SU2015 it lost the Quadface- Information and I have to reconvert it to quads, as you described above.
                              http://www.zz7.de
                                Any chance you can provide a sample model with exact steps (video?) of what you do?
                                • jo-keJ Offline
                                  jo-ke
                                  the sample model is attached above.
                                  here's the component:
                                  If you load it in SU7 it is already converted to quadface
                                  If you load it in SU2015 you have to convert it to quadface
                                  0-schal-leger-tex.skp
                                  http://www.zz7.de
                                    I do not see a difference in behaviour between the two versions. In both SU7 and SU2015 I had to use SandboxTools Quads to QuadFace Quads for the mapping to work.
                                    • jo-keJ Offline
                                      jo-ke
                                      On my machines in Version 7 the model is already converted and can be mapped directly.
                                      It is not really a problem, I was just a bit surprised of that fact.
                                      http://www.zz7.de
                                        Can you do a screen capture? I might be missing a step or something. There should be no difference between machines.
                                        • DareDevilD Offline
                                          DareDevil
                                          I missed this plugin ! I tried it now because I need quad (planar or non planar) for paneling surface. But I have some problems with the OBJ export (SU pro 2015 on Win 8.1 64)
                                          First, the export setup windows use an huge typo. So I can't see the Scale setup. I edited the CSS file to change it and it's almost OK...
                                          Second and worse, SU suddently close after export. The exported OBJ seems OK but SU dont like do that. Anyone have the same issue ?
                                            Screenshot? Do you have a high DPI monitor?
                                            Hmm... not seen that. Does it happen will all epxorts? Or does it happen with a particular model. If so, can you share it?
                                            Does it simply close? No BugSplat dialog?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 33
                                            • 34
                                            • 20 / 34
