    TreeSketch 2 for iPad [Free]
    31 Posts 10 Posters 2.5k Views 10 Watching
      This crazy app allows you to make 3d tree on your iPad and export them as .fbx. The textures don't export but if you've a jailbroken iPad you can dig into the directory and get the textures too.
      http://algorithmicbotany.org/TreeSketch/
      It's great fun to play with and the possiblities are endless. Check out these videos to see what I mean!
      [flash=400,300:12qeb065]http://vimeo.com/moogaloop.swf?clip_id=27135819&amp;server=vimeo.com&amp;show_title=0&amp;show_byline=0&amp;show_portrait=0&amp;color=00adef&amp;fullscreen=1&amp;autoplay=0&amp;loop=0" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=27135819&amp;server=vimeo.com&amp;show_title=0&amp;show_byline=0&amp;show_portrait=0&amp;color=00adef&amp;fullscreen=1&amp;autoplay=0&amp;loop=0" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object>[/flash:12qeb065]
      With some messing around you can get these into SU pretty easily but they are high poly!
      • PixeroP Offline
        Pixero
        Oh, how I wish I had an iPad...
          I was kind of surprised this didn't get more attention but then maybe not many have iPads?
          I will say this is unbelievable to use, so simple yet powerful!
          • mogrenM Offline
            mogren
            Thank you Rich it's magic!
            I didn't find a simple way to export a FBX file into SU Mac
              Have you tried Autodesk's FBX Converter...
              http://usa.autodesk.com/adsk/servlet/pc/item?id=10775855&siteID=123112
              ...scroll past the 3DS Max plugins to see the standalone converter for both Mac and PC.
              • HieruH Offline
                Hieru
                I was kind of surprised this didn't get more attention....
                Me too, it's a great application (as far as I can tell). I just assumed that most people don't have an iPad, or like myself, hadn't had chance to export their creations πŸ˜„ .
                I'll definitely report in when I find the time to use the trees. I really hope that the trees are useful as the creation process is incredibly intuitive and rewarding - OK, I'm addicted πŸ˜„
                www.davidhier.co.uk
                • HieruH Offline
                  Hieru
                  I've just started a test render and it has to be said that I'm already surprised by the quality of the trees. Judging by the onscreen iPad preview I expected something equivalent to Tree[D] - i.e only good for backdrops or mid-ground (at a push).
                  So far the tree I'm using looks pretty impressive. It's a pity about the textures, but the UV mapping looks sound, so alternatives are easy enough to drop into place. It might be helpful if the developers could provide a library of textures - I'll email them and see what they can do.
                  www.davidhier.co.uk
                  • EdsonE Offline
                    Edson
                    it sounds odd to me: an apparently complex app with wide potential use that runs only on iPads? πŸ˜•
                    http://www.mahfuz.arq.br
                    • HieruH Offline
                      Hieru
                      Since the modelling is based around the iPad multitouch interface, I'm not sure that it would be that easy to port it to other formats. I could be wrong though πŸ˜„
                      www.davidhier.co.uk
                      • soloS Offline
                        solo
                        looks interesting, but begs the question....why?
                        What is the point to this app? so you create a tree, then what? Is it just a doodling app?
                        My point is if this is a tree creator then what are you supposed to do with the trees?
                        I'd understand it if it was a PC/MAC app that then exported the tree for use in modeling/animation programs, the tree will then have a clear use.
                        I also do not want to have to jailbreak my ipad in order to use the trees.
                        http://www.solos-art.com
                          Did you even watch the videos?
                          It exports to .fbx so you can drag from iTunes to your Desktop.
                          • soloS Offline
                            solo
                            I watched the one you posted above.
                            iTunes, oh! πŸ˜• I'll skip that one, and wait for something similar to come to a PC near me.
                            • mogrenM Offline
                              mogren
                              Thank you I'll try soon
                              • HieruH Offline
                                Hieru
                                Here's a test render that should give some indication of the tree quality:
                                The trunk and branches could possibly do with being higher poly, but it's not too shabby with some smoothing applied.
                                www.davidhier.co.uk
                                • soloS Offline
                                  solo
                                  That's actually amazing!
                                  Too bad about the iPad workflow, I do not have one, or any plans to get one unless they drop under $200.
                                  • fuzzionF Offline
                                    fuzzion
                                    [attachment=0:2vm95tfl]<!-- ia0 -->TreeTest2.jpg<!-- ia0 -->[/attachment:2vm95tfl]
                                    πŸ’­ Post them on warehouse. Tittle them high poly trees. SO that those without the program can get even more free high quality trees. Mind you,
                                    Its 2011 and im still waiting for the Vray HDRI visualiser and SU tree maker plugin πŸ˜‰
                                    "Only the dead have seen the end of war" - Plato
                                    • HieruH Offline
                                      Hieru
                                      I think that the winning quality is the flow of the branch growth - plus the human touch added via the gesture based UI.
                                      I'll have to check to see what the policy is regarding sharing tree models, but presuming that this isn't an issue, I'll probably upload some of my creations via the Thea forum and 3D warehouse. The only thing I'm short on is free leaf and bark textures that I can distribute with the trees.
                                      www.davidhier.co.uk
                                      • soloS Offline
                                        solo
                                        Leaves, freeee: http://www.cgtextures.com/textures.php?t=browse&q=1763
                                          David can you share your technique after export?
                                          • HieruH Offline
                                            Hieru
                                            I converted the FBX to .obj and using File>Merge I imported the tree into Thea. I then applied a stock bark material to the trunk and branches and for the leaves I added a leaf texture to the Diffuse & Translucent material slots (plus a clipping mask) - I didn't change anything else.
                                            I've just tried importing into Sketchup and both .obj and .dxf result in bug splats. DAE works just fine, but the tree used in my render is 75MB, so it looks like I won't be able to upload anything to the 3D Warehouse. On top of that I don't much fancy texturing each individual leaf πŸ˜†
                                            www.davidhier.co.uk
                                            • 1 / 2
