    [Plugin] Shell
    93 Posts 33 Posters 64.9k Views 34 Watching
      j_forrester
      Is it possible to shell but keep the return from the original geometry. I have tried with JPP too but seems to fall down when you try it with and opening with single extruded returns.
      Many thanks
        The generated geometry is created in a separate group - if that is what you mean..?
          robert111
          i post my file and vedio for this bug
          bug00.rar
          shell bug.rar
          • jeff hammondJ Offline
            jeff hammond
            4.6MB for that.skp ๐Ÿ˜ฒ
            one word:
            PURGE ๐Ÿ˜„
            model info -> statistics -> purge unused.
            gets it down to around 150kb
            dotdotdot
              Your SKP will shrink to almost nothing IF you use Model Info > Purge Unused...
              Then there's no need to zip/rar it and others will be more willing to look at it!
              You don't appear to understand the idea of what makes a 'solid'.
              An 8 sided box is a 'solid' - all edges have 2 faces - no more, no less.
              Your group group has only 4 faces and several edges with only one face... so it's not a 'solid'.
              Select two groups in turn and see what the Entity Info dialog says... make one as a 6 sided box [it says it's 'Solid'] and yours will not say it's 'solid' !
              Therefore you can't do 'solid' operations on your group - it's not a 'solid'!
                ... I'm confused ... you're getting the error when trying to use Solids Tools?
                Shell doesn't require solids...
                Can you explain step by step what you are doing? (What you click on etc.) Also, what are you trying to accomplish.
                  robert111
                  i make box and i deleted 02 faces and i have group it
                  and after i click in this box and i click after shell plugin
                  i have make video for my file can you see it
                  the file video is shell bug.rar
                    Robert
                    As I tried to explain...
                    Shell and similar only only work if the group is a 'solid'.
                    An 6 sided box with no 'holes' is a 'solid'.
                    If you delete edges and/or faces then it is no longer a 'solid'.
                    The simple definition of a 'solid' group [or component] is that every edge in it has 2 faces attached to itself - but no more and no less...
                      No...
                      I will have a look at the sample video and see if I can understand what this whole is about.
                        Ah!
                        Now I understand what this all is about!
                        You're trying to use SketchUp Solid Tools's "Outer Shell" command - instead of "Shell" which is this plugin. I can see how you got confused.
                          Aha! ๐Ÿ˜ฎ
                          His video shows him trying to use [Outer] Shell on a non-solid object !
                          ๐Ÿ˜’
                            robert111
                            mr TIG, thanks you for your reponse but i dont know how to make any form to solid form with sketchup, can you make video tutorial for this plugin plzzz
                              See the responses on the previous page since your last visit: http://forums.sketchucation.com/viewtopic.php?f=323&t=39308&start=15#p365385
                                No.
                                If you do not grasp the concept of what a solid is how would showing you help?
                                Most simple forms made by Sketchup like boxes and cylinders are 'solids'.
                                When you add them together they can make internal partitions etc which need removing before it's considered to be a solid.
                                Try my SolidSolver tool which attempts to turn non-solid groups into solids...
                                However, your example of a 4 sided box could never be made a solid unless you add more faces/edge etc...
                                  But he doesn't need a solid at all. He simply confused the "Outer Shell" menu item for my "Shell" menu item.
                                    robert111
                                    thanks
                                    i confused the out shell with shell
                                    your plugin work perfect now
                                    thanks thomthom and thanks TIG too
                                      ๐Ÿ‘ ๐Ÿ‘
                                        chango70
                                        Great plugin, already works well for 0.2!
                                          boilingsnow
                                          This is really useful.
                                          Thank you so much.
                                          • OxerO Offline
                                            Oxer
                                            Thanks, i'm looking for something like this. ๐Ÿ‘ ๐Ÿ‘
                                            http://www.oxervision.blogspot.com/
                                            • 2 / 5
