    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 229.8k Views 51 Watching
    • fredo6F Offline
      fredo6
      @thomthom said:
      Have you noticed if it's building the toolbar or actually displaying it that consumes time?
      I think the toolbars are displayed after the whole load sequence. I infer this from the fact that when you have an error in one script, you get an error message box, and you can observe that the SU toolbar is not yet updated.
      On my PC with Windows 7, I get very fast load times, including for Toolbar creation. On XP, it is much slower, but still around 2 seconds for all my plugins
      Fredo
        Ben Ritter
        Thank you so much.
        • P Offline
          philkrantz
          I really need help. I've spent hours today trying to get this plugin to install. I even tried deleting sketchup completely and downloaded it again. Using mac os x 10.5 with sketch up 8. I need the plugin "round corners" I never successfully gotten a plugin to work and tried every step over and over. Could someone with a mac post screen shots of every step need to download a plugin. I know that sounds dumb, but I've exhausted all other attempts.
          • fredo6F Offline
            fredo6
            Just to be clear:
            1. you must put 000_AdditionelPluginFolders.rb in the Sketchup Plugins directory (so typically C:\Program Files\Google\Google SketchUp 8\Plugins)
            2. If you define an additional folder and you wish to install my plugins there, make sure that LibFredo6_Dir_40, LibFredo6.rb and the folder of my plgins (line ROUNDCORNER_Dir_23) are all located in this additional folder (they must resides altogether in the same place).
            3. You have a utility Windows > LibFredo6 Settings > View Trace Log Files that gives a status of what has been loaded in your current Sketchup session.
            Thanks to advise if this solves your issues.
            Fredo
            • gtalaricoG Offline
              gtalarico
              Fredo, thanks a bunch for this plugin.
              I can finally keep my plugins in my Dropbox and access/sync them across home PC, laptop & work!!!
              I had tried doing this manually the way TIG had suggested to me in a different post, but I kept having some plugins not loading, bugs etc.
              Anyway, I do have one question: I noticed that the Artisan toolbar was iconless (other toolbars were ok).
              I decided to try copying the artisan folder (not the loader) to the local plugin folder and the icons showed up:
              I guess this means artisan insisted in looking for its icons at the absolute local path?
              Is there a way to prevent/fix this?
              Thanks again!
              -Gui
              http://www.gtalarico.com
              • fredo6F Offline
                fredo6
                Thanks again!
                Some plugins rely on the standard Sketchup Plugin directory to find files and therefore won't work correctly if put in an alternate folder.
                Also, plugins usually require that their loader and subfolders are in the same location.
                For Artisan (by Whaat), I will post a request in the related thread.
                Fredo
                • Bob JamesB Offline
                  Bob James
                  Now that's a great idea. More than reason enough to download this plugin.
                  Thank you Fredo
                    gtalarico
                    Thanks Fredo.
                    My current work around is to keep a separate LOCAL plugin folder on my DB, and I update those manually.
                    -Gui
                      gtalarico
                      Although I can still think of many uses for this plugin, I have further improved my SU<>Dropbox integration by using the method suggested by andrea.bianco here:
                      http://forums.sketchucation.com/viewtopic.php?f=15&t=40866
                      (The workflow is even further simplified and improved by Brodie here (Page2):
                      http://forums.sketchucation.com/viewtopic.php?f=15&t=34019&hilit=+dropbox
                      I have now moved all SU folders (Components,Materials,Styles,Components) to my DB so they are in Sync at home and work by symlink-ing the folders in my DB to the SU folder. 😍
                      Sorry this not necessarily "AdditionalPluginFolders" related, by it ties in to the conversation above, and I thought it could be helpful for people that end up in this post for the same reason I did. (SU+DB)
                      -Gui
                      • sumasterS Offline
                        sumaster
                        Its work perfectly ........
                        Thank you Ferdo ......
                        I like your all plugins ..... its very useful for my sketchup 3D modeling .......
                        THANKS again ...... waiting new things or new PLUGIN .... THANKS
                        Thank you,
                        SUmaster
                          driven
                          Hi Fredo,
                          is there any chance the startup select directories dialog could have all 'options' in one dialog box, i.e. dir1, dir2, dir3 as opposed to a cascade.
                          also, is there any way to 're-select' one you need forgot.
                          It does work well
                          cheers
                          john
                          • fredo6F Offline
                            fredo6
                            This is possible. I use the standard SU dialog box because it is faster programming. But I can develop one which is more comfortable
                            Difficult, because you would have to re-execute the whole loading cycle to be sure to catch all plugins.
                            If you need to start Sketchup frequently with various configurations (i.e. list of plugins), I would suggest other methods, based on list of plugins (a little bit like the Extension Preferences, but in external files that you can edit. Then 000_additionalPluginFolders would simply skip or load plugins depending on the configuration files.
                            Let me think of it
                            Fredo
                            PS: the objective of my script was mainly to avoid the Security issues with C:\program Files on Windows, share plugins between SU6, SU7 and SU8, and trap errors at loading to avoid messing up the toolbars. This is not really a plugin manager!
                              driven
                              I been experimenting using it with my 'on_off.rb' and it's working quite well, the idea is, if I have a bugsplat I can restart with no plugins then load the culprit to see if it's it... if not I can run then this and re-introduce my common sets one at a time[by re-starting at the moment], then any stray rubies until the problem re-appears.
                              however it's also great for just limiting what I start with and only turning it on when I want an additional set.
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=41994#p372262
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=38726&p=372570#p372576
                              be great if you could have a look at my concept, in the one posted I just use the load single plugin option to load this after a rubies"OFF" startup ...
                              john
                                camoncamon2001
                                It's possible to load plugin directories from an external file (like .txt)?
                                  caronte01
                                  Hi Fredo;
                                  Great plugin, very useful for people working on different machines
                                  thanks!
                                  • G Offline
                                    gabegabe
                                    I've installed this beautiful 000_AdditionalPluginFolders (v3.0a - 23 Aug 11)
                                    I have some compatibility problems with SU Podium Rendering Plugin
                                    Windows 7 64bit:
                                    When I put 000_AdditionalPluginFolders.rb in Google Sketchup Plugin FOLDER, SU Podium is NOT loaded;
                                    When I remove 000_AdditionalPluginFolders.rb into Google Sketchup Plugin FOLDER, SU Podium is regulary loaded
                                    Windows XP 32bit:
                                    When I put 000_AdditionalPluginFolders.rb in Google Sketchup Plugin FOLDER, SU Podium is loaded, EXEPT Pobium Browser;
                                    Mac OSX Lion:
                                    When I put 000_AdditionalPluginFolders.rb in Google Sketchup Plugin FOLDER, SU Podium is loaded, EXEPT Pobium Browser and I receive a LOG error message;
                                    Any suggestions?
                                    Thank You
                                    • JQLJ Offline
                                      JQL
                                      Thanks Fredo for this very useful plugin.
                                      I've noticed something strange though:
                                      I have created two folders outside the program files directory:
                                      Original Folder - is the standard plugin's folder and had only your plugin.
                                      Folder 1 - has all my plugins
                                      Folder 2 - has the plugins I am testing and may delete
                                      I noticed the projections_v2 plugin was not working although it displayed all the icons on the toolbar. It was the only one. I moved it to the Original Folder with its tassociated folder (wich in this case had the .png icon files and a .rbs). When I did that the plugin started working but all the icons were gone from the toolbar. I copied the icon files from the Original Folder to Folder 1, keeping the same file struture. Everything is correct now.
                                      I noticed the same thing happening to another plugin that I was testing and was in Folder 2, (pointool.rb) but this does not happen to all plugins.
                                      Is it possible that Sketchup is assuming that Folder 1 is the main plugin folder? Is it possible that there are multiple ways of assigning paths inside plugins and some of those ways are causing those errors?
                                      For me the problem no longer exists, but it may interest you. Thanks again and best regards.
                                      www.casca.pt
                                      Visit us on facebook!
                                      • 2 Offline
                                        26delta
                                        Ever since installing 000_AdditionalPlugiFolders, I have been getting error messages regarding win32api.so and the windows.rb and parameter.rb files. The first indicates that the procedure Init_win32api cannot be found in win32api.so.
                                        As far as I know, that procedure has never existed. The second error message indicates that the windows.rb cannot find the parameters.rb file and the third error message repeats the first. I'm at a loss.
                                        • TIGT Online
                                          If you move scripts [.rb/.rbs files] - and their subfolders of supporting files etc - out of the main Sketchup Plugins folder into another folder that has been added onto the $LOAD_PATH list [as with "000_AdditionalPluginFolders"], then they will still load/work OK, as they will auto-load like they used to from the main Sketchup Plugins folder.
                                          However, if the scripts ' require' some other file[s] to be preloaded [like 'parameters.rb' or 'win32api.so'] then any 'required' files also have to be in a folder included in $LOAD_PATH too. If it's not then you'll get a 'load error'.
                                          The windows.rb has the line at it's start
                                          require 'parametric.rb'
                                          to ensure that the methods available from that code are available to the 'windows' code...
                                          You might also see that it has
                                          require 'sketchup.rb'
                                          but as that must always to be kept in the Sketchup 'Tools' folder, with other 'system' files, and that particular folder is automatically added to the $LOAD_PATH list, then there are no errors about that.
                                          So it expects a 'required' file to be somewhere in the folders listed in $LOAD_PATH.
                                          If the file is missing you get the error messages.
                                          The missing 'parametric' file is available here http://sketchup.google.com/intl/en/download/rubyscripts.html
                                          Some '.so' files are available here... http://forums.sketchucation.com/viewtopic.php?p=380121#p380121
                                          Also note that some scripts might try to find/use files passing an exact path using say
                                          load(Sketchup.find_support_file("argh.rb", "Plugins"))
                                          where this method will always look for that file in the Sketchup Plugins folder, irrespective of where the script that's looking for it might now be located, so moving any related files over with the script will fail to get the desired files/code loaded if it hasn't been left in Plugins.
                                          This is particularly limiting if the script's supporting files are in a subfolder with a path that's hard-code to be always in Sketchup's Plugins folder using this method - relocating the subfolder will then fail to load then files properly.
                                          If the desired file is always to be kept with the script that's looking for it, then a safer option in the coding is to use
                                          load(File.join(File.dirname(__FILE__), "argh.rb"))
                                          as this is then looking in the actual script's folder [whatever that might be] for that desired support file.
                                          • 2 Offline
                                            26delta
                                            That's the rub. The .rb files ARE in the default Plugins folder.
                                            The major problem reported in errors 1 and 3 is that there is reference to a procedure 'Init_win32api' which (according to the Win32api.rdoc) does not exist. This may be causing the failure to recognize parameters.rb in error 2. I have reloaded Sketchup and the plugins to no avail.
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
