    Table Leg Need Help
    14 Posts 6 Posters 1.5k Views 6 Watching
    • david57D
      david57
      I don't know if the gallery is the right place to ask for
      help.
      Ive been working with 3d legs as in the image. Is there
      a plugging that will do this kind of work automatically
      with the curve on the left ?
      • J
        jdadesignstudio
        Check this thread:
        http://forums.sketchucation.com/viewtopic.php?f=15&t=38995
        • G
          gulcanocali
          Hi david57,
          This would be very easy to do with Tgi3D SU Amorph's cross section tool. Take a look at the videos below, you can use your outline the same way we use the picture of the glass in the first video or just create the shape as desired without the outline as in the second video.
          BTW, the cross section tool is included and unlimited in the free Training Edition πŸ˜‰ You can download it here
          [flash=600,492:3okxv9mf]http://www.youtube.com/v/DFMbyZIonwQ?fs=1&hl=en_US[/flash:3okxv9mf]
          [flash=600,492:3okxv9mf]http://www.youtube.com/v/11mhfNJlduE?fs=1&hl=en_US[/flash:3okxv9mf]
          Gulcan Ocali
          Product Manager
          http://www.Tgi3D.com
          • david57D
            david57
            Thanks Jon.
            Thanks Gulcan.
            • R
              Roger
              help.
              I am not sure how you already got the results that you did, so I apologize if the method I am about to describe is the same.
              1. Draw your profile and surround it with a rectangle.
              2. Now you have a flat rectangle with the profile in the center.
              3. Knock out the center of the profile so you have a profile shaped hole in the rectangle.
              4. Make a horizontal line at the top and bottom of the profile and divide by as many times as you think you need for desired smoothness.
              5. Clip any excess line length so your profile shaped hole is crossed by horizontal lines
              6. The result should look like a harp with horizontal strings.
              7. Select the harp and make it vertical.
              8. Group and lock the harp so it won't move and further construction will not attach to it.
              9. Now make a circular column the exact height of the profile.
              10. Divide the column by the same number of times you divided the profile.
              11. Drag the column into the locked harp so the center of the column hangs from the mid point on the top of the profile.
              12. Hide the outside skin of the column to you only see the disks
              13. Scale the first disk from its center so its diameter matches the length of the top of the profile
              14. Move the center of the second disk so it aligns with the center of the next line in the harp
              15. Enlarge the second disk around its center to match the size of the second line
              16. Repeat steps 14 and 15 for the number of lines remaining.
              17. When you reach the bottom unhide the entire outside skin.
              18. Erase the harp and only your curved leg surface remains.
              Until someone writes a plugin, this work flow should make the workflow pretty efficient.
              Now you can tell me if this is what you were doing.
              http://www.azcreative.com
                If you've got the slices drawn, and since you asked about a plugin, Chris Fullmer's Simple Loft would handle it
                • david57D
                  david57
                  Roger,
                  That's to much, to many steps for me
                  to follow. I got lost. I would just like to click
                  on the curve have all those steps done in an instant.
                  Dave,
                  Yes, those are slices or edges and from
                  those edges i use a ruby script Circle From Edge.
                  And the circles are connected with Curviloft.
                  I also wanted to make the eagle's claw the same way
                  with edges and circles as in the leg.
                  I would draw the fingers as a curve as in the leg.
                  Maybe in the future some one will make a script for 3d objects
                  to be created from a curve.
                    I'm just curious. How are you generating those slices for the talons on the ball and claw? Are you just kind of eyeballing things or do you have something to go by?
                    I've looked for a good way to draw claw feet for awhile--something that would be straightforward and easy to teach others to do. I'm looking for more detail than you've got there, too. I've got methods for drawing them that work for me but they aren't as streamlined as I would like for teaching.
                    • david57D
                      david57
                      Add a part of a claw with a finger nail.
                      • david57D
                        david57
                        Dave R,
                        Yes, those slices were placed eyeball or set at
                        random at different distances on the curves. The
                        extra length past the curve is deleted.
                          Cool. Now carve a bunch of those in mahogany. πŸ˜„
                          • david57D
                            david57
                            Yes, in the real world they have CNC Machines that do that.
                            I had a job as a jeweler and my boss wanted me learn how to operate one
                            of those machines. The price of Gold and Silver went up very high and fast
                            and i was left with out a job. Jewelry was not selling. 😞
                              Nah. No CNC for that. Do it like the real woodworkers and carve them by hand. πŸ˜‰
                              Maybe the jewelry business will come back.
                                What's a hnad Dave?
