    How to do this ?
    24 Posts 6 Posters 2.0k Views 6 Watching
      Bertier
      statue on the left : 65K polys.. (3d laser scan ...)
      statue on the right : 2k polys (poly reduction out in a 3rd party program)
      2 questions :
      • how to do that in SU8 ?
      • for movie purpose : when my camera is far from the model I want statue on the right, when I get closer I want statue on the left ? any ideas ?
        --> the closer I get the more details I want.
      thank you for your input
      differences that matter
        Sds2 has a Polyreducer tool
        TGI3D Amorph has a Downsample tool
          Bertier
          hey Rich,
          what is Sds2 ?
          ok so that's is for polyreducer...
          what about dynalic reduction like in Google Earth when I move closer to an object?
            An another polyreducer plugin 😉
              Hi Bertier,
              SDS2 is also known as Artisan. Pilou's link is to the earlier version of Polyreducer which is now revamped and more stable in SDS2
              (www.artisan4sketchup.com)
              There's a fifteen day trial so loads of time to tweak some models.
              Tgi3D Amorph's Downsample feature is fairly robust too and it's got a trial period too.
              As for your other request maybe Xref by TIG? But that is something I've no idea about 😕
                What he's talking about is LOD ( Level Of Detail ). He want to use low poly mesh when the camera is far away and high poly when the camera is close. Automated.
                No existing tools AFAIK.
                  Jim
                  Furthermore, he's talking about dynamic polygon reduction as a function of camera distance. This isn't very practical from my experience writing and using Ruby plugins - it would be too slow.
                  One alternative would be to use just 2 or 3 levels of detail in a single Component, and cycle the visibility as a function of camera distance.
                  Or maybe Fredo's GhostComp?
                  • TIGT Online
                    My earlier 'Proximity' tool [part of Matrix-Proximity] did this swapping of three types of component definition with affix [+/~/-] depending on each instance's distance from the camera's eye... BUT you had to do it scene by scene - adding detailed instances near the camera at each view point then rendering each in turn etc... It keeps poly count down but is cumbersome...
                      I thought he was asking about having a component replaced dynamically from a set of already reduced versions...
                        That was it Matrix Proximity. I knew I was wrong with XRef. But what does XRef do?
                          Jim
                          Or that.
                          • TIGT Online
                            He was asking for automation.
                            Proximity is that, but manual... BUT you could adapt the idea to [semi]automatic but it'd be a massive overhead in processing the changes...
                            [Xref Manager lets you update external SKPs that are inserted as components, if they've been changed since they were originally added [or last updated] into this SKP etc...]
                              Yea, I think that auto-update when the camera moves will in all likely hood cause too much of a performance hit. And there is no knowing if making changes to the model might interfere with other plugins or whatnot.
                              But being able to define a set of distance ranges and components - which would be adjusted on the click on a button, that would be interesting for staging scenes for rendering from various angles.
                              • TIGT Online
                                Proximity does that [has done for years] - you set the distances and if any components have the matching 'proximity' types with the affix +/~/- [near/mid/distant] and they are within the specified distance ranges then they get swapped in that view to be the appropriate type...
                                Thus any detailed trees are used near the camera in that view and simple ones further away...
                                  Bertier
                                  thank you for your interest into this.
                                  I will try the poly reduction techniques this morning and test TIG's plugins
                                  still I go with ThomThom :
                                  *by thomthom on Tue Jul 05, 2011 11:24 pm
                                  (...) being able to define a set of distance ranges and components - which would be adjusted on the click on a button, that would be interesting for staging scenes for rendering from various angles.*
                                  this is exactly the issue, i am into film making these days... with lots of statues / artifacts / buildings.
                                  very large set.
                                    So it is related to animation making you want this LOD feature?
                                    Flythrough, or do you use an animation plugin?
                                      Bertier
                                      it will be fly through
                                      no animation involved
                                      yet we need motion blur, but it'll be post prod I imagine
                                      • TIGT Online
                                        You could envisage a version of Proximity linked to a Scene-Observer so as a scene changed the components would get swapped around but it will be sloooooow... Perhaps making it as image frames rather than a movie would be best ?
                                          Bertier
                                          well that is the idea
                                          image frames : 25 fps
                                          render with ???? not decided yet
                                          processed in Adobe Premiere or equivalent
                                            Why not try OpenSpace 3D ?
                                            It's in French made by Frenchy people 😉
                                            I have made a little video for Sketchup to OpenSpace3D 😉
                                            • 1 / 2
