    Why Sketchup?
    31 Posts 22 Posters 4.0k Views 22 Watching
    • Y
      yeahright
      Hi! I've just started using Sketchup and doing a bit of exploration of some of the work you guys are up to - and it's amazing!
      I was just wondering, with all of the 'pro' (e.g. Blender, Maya etc.) software out there, what made you stick with Sketchup? What does it offer you that the others don't? I guess the obvious one is money, but I'm sure there are other reasons?
      Cheers!
      • B
        bjornkn
        Power, speed, workflow, fun, ease-of-use, extensibility/plugins.
        Just a few reasons...
        • D
          d12dozr
          What Bjorn said, plus...this community! β˜€
          http://goo.gl/f7ooYh
          • HieruH
            Hieru
            +1 For all of the above.
            Unlike other programmes the simplicity of the UI means that there isn't much of a barrier between conception and execution.
            www.davidhier.co.uk
            • L
              ledisnomad
              I'm with Pilou: SketchUp is just plain intuitive. Blender on the other hand, which is also free, and arguably more versatile, if very difficult to use--at least from my limited experiences with it over the years. And then there is the visualization aspect: SketchUp is immediately legible. With it's real-time shadows, simple toon style, and easy export to reasonably high-res, antialiased images, you don't need to spend a lot of time learning to render in order to communicate conceptual ideas.
              Intuitive.
              Excellent visualization.
              For me, those are the two biggest reasons.
                The perfect learning tool. Extremely intuitive and flexible.
                • brodieB
                  brodie
                  I'm lucky enough to work for a large design-build firm. We have licenses for SU, Rhino, 3ds Max, and Revit all of which I've worked with to a greater or lesser extent (I've also played with Blender a bit) so money isn't the issue for me. I would say that of all those I've tried 3ds Max is by far the most robust. It can do anything. But that's also it's problem. It does so much stuff that to get fast and proficient with it would take a lot of time, training, and customization.
                  I've stuck with SU for the past several years because it's extremely fast and intuitive - particularly for archviz. However, at a certain point you do run into limits involving poly and file size (not really an issue unless you're doing rendering).
                  -Brodie
                  • Mike LuceyM
                    Mike Lucey
                    SketchUp was design to work the way a Newbie would imagine it should and it does! No mental gymnastics needed at any stage of the process, the next step in the building / design process is alway obvious πŸ‘
                      It's the only one that you can master after 15 minutes! β˜€
                      Even kids from 5 years old! 😎
                      • GwyattG
                        Gwyatt
                        Why Sketchup,,, Very good question
                        For me Who is not a pro designer this was my feeling
                        Sketch up free version is a Perfect starting block for floor plans and so easy to learn in five minuets turn a sketch on the back of a ciggy packet to a working drawing and it doesn't cost you a penny to produce but your time, as you click you have walls with the advance users Model database you and furnish that model produce a working concept that just landed you a paid contract. as your skills grow (others here very advanced) With no need to understand meshes and all the information you need to use max 3d (Auto Cad products)and other alike and not forgetting the cost to pay to train and learn them packages on top of the price of software mounts to Β£1000s,
                        After 6 months of learning sketch up from Free Forums and U-tube, all it cost me was my free time I purchased pro with the Lay out export option saves so much time with sending out plans to clients, thanks to all the Skilled people here the tips plug'ins and much more and (Kerkythea Team) I have learned 1000s of pounds worth of knowledge.
                        So end of the day i Love the speed the quick response i get from sketchup, the support and advice from all the users, the last time i used a 3d package was Light wave with Amiga 040/video toaster for fun with friends as they gave it away free on Amiga format.
                        So to date thank you to the team here for all the tips and advice that no other 3d package has that support And that's Why Sketch up Is the one
                        • soloS
                          solo
                          Why Sketchup?
                          Simple.... Because modeling is supposed to be fun and creative not complicated and cryptic.
                          http://www.solos-art.com
                          • V
                            voodooman
                            I am an experience computer user, I design software for a living.
                            My interest is house design and conception. My wife and I have built a property portfolio of houses for a pension.
                            IMHO Sketchup is not good for House or building design. I use Arcon myself, it kicks Sketchup into next week as far as I am concerned.
                            However for conceptualisation and 3D illustrations Sketchup is awesome. I use it for all sorts of things, studwork, kitchen layouts, bathroom layouts. I get the drawings for the baths,units etc and make them in Sketchup, I can then see exactly what they look like. I make 3D drawings for my contractors so they can see exactly what I mean.
                            I found Sketchup hard to get into and still run into problems. Compared to Autocad it is easy. You get out what you put in.
                            Maybe one day I will be an expert like some of the people here but in the meantime I will carry on trundling out wicked 3D illustrations, get a buzz out of every one!
                            Peter
                            • E
                              Ecuadorian
                              A lot of us are architects. SketchUp is almost perfect for us: Way more freedom than ArchiCAD, but not as intrincate as Maya or Max.
                              -Miguel Lescano
                              • Y
                                yeahright
                                Wow - what an awesome response!
                                Cheers for all of your responses. I have to be honest, I'm still feeling the pull towards more 'pro' packages - specifically Maya - mostly due to the possibility of future employment... I guess I don't want to invest too much time in something (Sketchup) if I'm going to move on to something more powerful (Maya) in a few months.
                                Does that make sense or am I talking gibberish? πŸ˜„
                                • soloS
                                  solo
                                  well not unless you are attempting something incredibly organic that might be more suited to Z-Brush
                                  And yes there are freaks that try doing those models in Sketchup...idiots. πŸ’š
                                  • L
                                    ledisnomad
                                    Hey, yeahright.
                                    Very interesting discussion you started. Thanks.
                                    What's your intended use? You mention employ-ability, so you are looking at software packages to learn as career skills, right? There's another dimension to "why sketchup?" if you have a particular use in mind. Some people have mentioned architecture, archviz, interior design, set design, exhibit design; there's game design people on this forum, too, and I'm sure many, many other professions. However, there are many people here that can point out all the shortcomings of SketchUp right along with its strengths. That's where you need to know WHAT you are using it for.
                                    Organic shapes? Don't use SketchUp.
                                    Maybe you need BIM or parametric features, so something like Revit, Bentley GC, or CATIA.
                                    Are you doing fabrication? Maybe SolidWorks.
                                    Are you going to do character animation? Maya, Blender, or something with character rigging... now I'm getting into territory I know very little about.
                                    So, what profession are you in? I have a philosophy that one should use the right tool for the job. I use SketchUp, Rhino, AutoCAD, and Revit all the time and often work between programs depending on the project or the task. I think one should learn the concepts behind modeling, rendering, scripting, etc. so it is that much easier to learn a new tool when you need it.
                                    • J
                                      julyyen
                                      I have the same opinion and feeling like Pilou, even my 7 years old little boy draw in SketchUp since he was 5 and every time i checked the forum for new posts, when I see new plugins appearing, he says - dad, let's try all this!!
                                      Finally, when I use this fantastic piece of software I fell free and ideas comes easy.
                                      • A
                                        ArCAD-UK
                                        Because it's actually quick and fun to design with, unlike some BIM monsters out there that tie you down with programed limitations and administrative complexities.
                                        • jeff hammondJ
                                          jeff hammond
                                          Not saying I'm a sketchup master but it did take quite a bit longer to really learn it.
                                          At least a year or two but maybe I'm slow. πŸ˜‰
                                          dotdotdot
                                          • tademaT
                                            tadema
                                            yeahright, what a great thread you've started here. Almost every post so far has the answer to your question...fun. For me Sketchup is so versatile it's like a cordless drill but plug it in (plugins) then it becomes a mighty hammer drill, often under rated to what it's really capable of.
                                            John
                                            • 1 / 2
