    Where is Susan?
    22 Posts 7 Posters 8.0k Views 7 Watching
    • charly2008C Offline
      charly2008
      Hi All,
      Where Susan is hiding? In the Components window is displayed a path that I can not find on my hard disk. Any help is welcome. I could also not find any Susan.skp (It may be that I have deleted her from the components sampler).
      Charly
        C:\Program Files\Google\Google SketchUp 8\Components\Components Sampler
        • jeff hammondJ Offline
          jeff hammond
          @charly2008 said:
          Hi All,
          Where Susan is hiding? In the Components window is displayed, a path that I can not find on my hard disk. Any help is welcome.
          Charly
          i think she's inside the template .skps
          (and not available as her own susan.skp component)
          could be wrong of course.
          ..and that path appears to be a mac path.. the same path is listed on my computer for susan's loaded from..
          so, more likely than not, snicolo is the user name of whoever created the sketchup templates..
          dotdotdot
            Simone is hiding her. 😉
              jeff hammond
              damn.. what a rip-off..
              i guess window sketchup actually IS superior to the mac version 😄
              [edit]
              hahaha.. holy s
              she's right there in the screenshot!
              i'm blind.
              (2D Woman Susan.skp)
              dotdotdot
                i'm blind
                Yes you are. Next time you're in a shop buying a laptop open your eyes and get a PC.
                  jeff hammond
                  i'm blind
                  haha. ok
                  dotdotdot
                    charly2008
                    Thanks for your comments,
                    I asked this question because I somehow managed to eliminate Sang at the start in Sketchup 7 and i would like to do the same in Sketchup 8.
                    Charly
                      Why not just delete Susan from your template then overwrite that template? No need to remove her completely from system to that.
                        And even if you remove from the system, she will remain in your template.
                          In a new SketchUp window, delete Sang/Susan/Bryce/Csaba and then click File > Save As Template.
                          Also do not forget to purge unused components before saving as a template.
                            SketchUpNoobie
                            In a new SketchUp window, delete Sang/Susan/Bryce/Csaba and then click File > Save As Template. Give it a name and set it as your default template. You can also use this method to change your default view when you open SketchUp. Just orbit/pan/zoom around to your desired default view and save the template again.
                            Hope I was clear. 😕
                            Edit: Rich beat me but I'll leave this up in case you're not sure how to do it.
                            SketchUpNoobie: the complete noob in all things SketchUp.
                              SketchUpNoobie
                              😮 I never thought of that! Thanks! 😄
                                Csaba?
                                I've no little angry lunatic in my SU?
                                  Sure you do - what did you think was causing BugSplats... 😒
                                    charly2008
                                    Thanks Rich,
                                    it Is so simple. I saved my workspace as a template without Susan, problem solved. Sorry Susan.
                                    Charly
                                      No worries Charly and no offence to Susan but I don't like it loading either. Although having Csaba loading would be a novelty.
                                      Pete, if you read this we need a 2D of that Green Csaba you posted months back 👍
                                        charly2008
                                        But I've found a replacement.
                                          Ah well, I doubt Susan would have posed like that for modelling...
                                            charly2008
                                            Hi Gaieus,
                                            You're right, I doubt that too.
                                            • 1 / 2
