    Where is Susan?
    22 Posts 7 Posters 8.5k Views 7 Watching
      i'm blind
      Yes you are. Next time you're in a shop buying a laptop open your eyes and get a PC.
      • jeff hammondJ
        i'm blind
        haha. ok
        • charly2008C
          charly2008
          Thanks for your comments,
          I asked this question because I somehow managed to eliminate Sang at the start in Sketchup 7 and i would like to do the same in Sketchup 8.
          Charly
            Why not just delete Susan from your template then overwrite that template? No need to remove her completely from system to that.
            • GaieusG
              And even if you remove from the system, she will remain in your template.
              • GaieusG
                In a new SketchUp window, delete Sang/Susan/Bryce/Csaba and then click File > Save As Template.
                Also do not forget to purge unused components before saving as a template.
                  SketchUpNoobie
                  In a new SketchUp window, delete Sang/Susan/Bryce/Csaba and then click File > Save As Template. Give it a name and set it as your default template. You can also use this method to change your default view when you open SketchUp. Just orbit/pan/zoom around to your desired default view and save the template again.
                  Hope I was clear. 😕
                  Edit: Rich beat me but I'll leave this up in case you're not sure how to do it.
                  SketchUpNoobie: the complete noob in all things SketchUp.
                    SketchUpNoobie
                    😮 I never thought of that! Thanks! 😄
                      Csaba?
                      I've no little angry lunatic in my SU?
                        Sure you do - what did you think was causing BugSplats... 😒
                        • charly2008C
                          charly2008
                          Thanks Rich,
                          it Is so simple. I saved my workspace as a template without Susan, problem solved. Sorry Susan.
                          Charly
                            No worries Charly and no offence to Susan but I don't like it loading either. Although having Csaba loading would be a novelty.
                            Pete, if you read this we need a 2D of that Green Csaba you posted months back 👍
                            • charly2008C
                              charly2008
                              But I've found a replacement.
                              • GaieusG
                                Ah well, I doubt Susan would have posed like that for modelling...
                                • charly2008C
                                  charly2008
                                  Hi Gaieus,
                                  You're right, I doubt that too.
                                  • jeff hammondJ
                                    likewise, purging will rid the template of all her colors so you'll be able to start off with a blank slate of materials..
                                      SketchUpNoobie
                                      😲 😮 That's were all those were coming from! Man, I feel so dumb right now. 😒
