    Help !!! Bug in my Sketchup8.. HELP PLEASE
    13 Posts 5 Posters 11.4k Views 5 Watching
      moonlander1954
      Hi, can someone help me understand my problem...I've dowloaded Sketchup8 French Version and intalled, everything is working normally but when I tried to put 2 new plugins, they did not appeared in Sketchup. I unzipped the files directly in Sketchup plugins and overwritten LibFredo6 before installing the new plugins (ToolsOnSurface and RoundCorner). If I go to Tools in Sketchup, I can see Fredo6 Collection but I have the previously intalled plugins (Curviloft, FredoScale, FreeScale) and they are working perfectly. I don't see ToolsOnSurface and RoundCorner anywhere...If I look in Window, Preferences, Extensions, I can see that the plugins name are there and they are checked as the others so why can't I have these tools like the others...Perhaps there is something I don't understand...Thanks to those who could help...André
        I have them all here (see attached). Your installation seems to be all right. Can you also not see their toolbars under View > Toolbars?
          moonlander1954
          Hi Gaieus, Thanks for taking time to give me an answer or trying to help me...I previously had these plugins in Sketchup7 and it was working very well but now , If I go to View in Tools Bar, they are not in the list and like I told you, they are not in Fredo6 Collection...Strange situation. I've been using Sketchup for a few years only for fun, nothing commercial or other and never had this kind of problem. Since it looks like I have done the right thing and put the files in the right place, howcome they are not there. I've used ToolsOnSurface a lot with Sketchup7 and really need it to go on. I uninstalled Sketchup8 and everything else and installed it again but the problem is still there. If you have a solution, I would really appreciate...André
            Try removing everything and downloading it again. AFAIK there is a newer version of (at least) LibFredo now.
              moonlander1954
              Hi Gaieus, thanks for the answer...by removing everything do you mean the plugins and libFredo6 ONLY from Sketchup8 or FLUSH EVERYTHING (Sketchup8 Plus The Plugins and LibFredo6 and reinstall ...dowloading the plugins again with the new libFredo6...André
                No, only LibFredo and ToolsOnSurface for the time being.
                  I'm wondering... Do you use Vista or Windows 7?
                  Do you see a button called "Compatibility Files" when you browse your plugins folder?
                    moonlander1954
                    Hi Gaieus And ThomThom, thanks again for trying to help me. I've dowloaded the Plugins and LibFredo again so I will do what you told me and reinstall ToolsOnSurface,RoundCorner and LibFredo6. For ThomThom...I'm using Windows 7 XP Family Edition since my computer is a little bit old but still working fast enough for what I do. For the button you mentioned, I don't see it.
                      That's a >=Vista button - Vista sometimes prevents you from adding files or folders into a folder if the 'permissions' aren't set to allow you full rights - but it lets you think you've done it, when it's actually put them into the compatibility files subfolder! This doesn't happen with XP - it either lets you do it or stops you doing it! [which seems far more logical than the new improved Vista way!!]. So that's one possible issue eliminated...
                      Try reinstalling everything - one tool [or tool+essential libs etc] at a time - and try SUp again - make sure you've read the instructions for each tool you add as some have different ways of 'activation' - e.g. Preferences > Extensions, View > Toolbar or they can have their menu items not necessarily under 'Plugins' etc...
                        moonlander1954
                        Hi TIG, First of all, thanks for helping me and taking time...I did what Gaieus told me and I still have the same result...I can't see ToolsOnSurface and RoundCorner in Fredo6 Collection but I still can see Curviloft, FredoScale, FreeScale and they are working perfectly...Strange. I'm using Windows7 XP Family Edition...I will try like you said to reinstall everything the way you told me, one tool at the time...André
                          moonlander1954
                          Hi Gaieus, ThomThom and TIG... THANKS A LOT FOR ALL YOUR HELP... I followed all of your great advice and now everything is back to normal...So thanks again and have a nice weekend...André
                            jjbrown
                            PLEASE HELP ! ! AM running OS 10.11.06 sketchup pro 2018 an trying to load libfredo6 an for some reason its not loading in extension warehouse ... ive even tried loading it into sk 2017 with no luck . just cant figure this out .....
                              Download the latest version from our PluginStore, https://sketchucation.com/pluginstore?pln=LibFredo6
                              The RBZ should then be found where you specified - usually your Downloads folder ?
                              Use the native Extension Manager > Install Extension, find the RBZ file and install it.
                              Remember that LibFredo does nothing much if installed on its own.
                              It is however required by most of Fredo's Extensions...
