    Help !!! Bug in my Sketchup8.. HELP PLEASE
    13 Posts 5 Posters 10.9k Views 5 Watching
      Try removing everything and downloading it again. AFAIK there is a newer version of (at least) LibFredo now.
        moonlander1954
        Hi Gaieus, thanks for the answer...by removing everything do you mean the plugins and libFredo6 ONLY from Sketchup8 or FLUSH EVERYTHING (Sketchup8 Plus The Plugins and LibFredo6 and reinstall ...dowloading the plugins again with the new libFredo6...André
          No, only LibFredo and ToolsOnSurface for the time being.
            I'm wondering... Do you use Vista or Windows 7?
            Do you see a button called "Compatibility Files" when you browse your plugins folder?
              moonlander1954
              Hi Gaieus And ThomThom, thanks again for trying to help me. I've dowloaded the Plugins and LibFredo again so I will do what you told me and reinstall ToolsOnSurface,RoundCorner and LibFredo6. For ThomThom...I'm using Windows 7 XP Family Edition since my computer is a little bit old but still working fast enough for what I do. For the button you mentioned, I don't see it.
                That's a >=Vista button - Vista sometimes prevents you from adding files or folders into a folder if the 'permissions' aren't set to allow you full rights - but it lets you think you've done it, when it's actually put them into the compatibility files subfolder! This doesn't happen with XP - it either lets you do it or stops you doing it! [which seems far more logical than the new improved Vista way!!]. So that's one possible issue eliminated...
                Try reinstalling everything - one tool [or tool+essential libs etc] at a time - and try SUp again - make sure you've read the instructions for each tool you add as some have different ways of 'activation' - e.g. Preferences > Extensions, View > Toolbar or they can have their menu items not necessarily under 'Plugins' etc...
                  moonlander1954
                  Hi TIG, First of all, thanks for helping me and taking time...I did what Gaieus told me and I still have the same result...I can't see ToolsOnSurface and RoundCorner in Fredo6 Collection but I still can see Curviloft, FredoScale, FreeScale and they are working perfectly...Strange. I'm using Windows7 XP Family Edition...I will try like you said to reinstall everything the way you told me, one tool at the time...André
                    moonlander1954
                    Hi Gaieus, ThomThom and TIG... THANKS A LOT FOR ALL YOUR HELP... I followed all of your great advice and now everything is back to normal...So thanks again and have a nice weekend...André
                      jjbrown
                      PLEASE HELP ! ! AM running OS 10.11.06 sketchup pro 2018 an trying to load libfredo6 an for some reason its not loading in extension warehouse ... ive even tried loading it into sk 2017 with no luck . just cant figure this out .....
                        Download the latest version from our PluginStore, https://sketchucation.com/pluginstore?pln=LibFredo6
                        The RBZ should then be found where you specified - usually your Downloads folder ?
                        Use the native Extension Manager > Install Extension, find the RBZ file and install it.
                        Remember that LibFredo does nothing much if installed on its own.
                        It is however required by most of Fredo's Extensions...
