    Subdividing faces for displacement plugin
    25 Posts 8 Posters 5.6k Views 8 Watching
    • srxS Offline
      srx
      Well, I didn't wrote one ๐Ÿ˜„, but maybe you can.
      The common problem when exporting to render application - for me this is Thea render.
      Faces which material will be displaced needs more subdivisions.
      How to fast evenly subdivide all the faces with that material only?
      The plugin with this function would be welcomed.
      www.saurus.rs
        Try thomthom's Edge-Tools - search the Plugins-Index...
        • srxS Offline
          srx
          I already use Edge tools. You mean Divide face tool? It is too manual. It would took me ages...
          I was thinking about more automotive work flow.
          1 Input - one or more materials (for example stone)
          2 Output - All the faces with stone material applied are subdivided evenly (more or less). This is what displacement needs.
          Wright now I do it this way:
          Make raster with sandbox tool parallel to the surface I want to subdivide.
          Project this raster onto the surface.
          This works for the terrain. But if I want to subdivide all walls (and ceilings) in the house?
          This is kind of reversed "remove collinear edges" command - Add collinear edges ๐Ÿ˜„
          www.saurus.rs
            Can you show an image of your preferred subdivided mesh?
              It should be anything that resembles the sandbox from scratch. Ideally dividing the face into squares (maybe also option for triangulation).
              Problem with Thea's native subdivision (and most of the subdivision tools available) is that it subdivides faces based on equal subdivision of the edges - i.e. when a face is not square, the subdivision will not be squar-"ish" either. But this is the ideal subdivision for displacement.
                Tgi3D Amorph upsample feature produces this result. Give it a try
                  Nope. As I said, these plugins divide each bounding edge equally. So there are no squares but longish rectangles only.
                    I see ๐Ÿ‘
                    • jason_marantoJ Offline
                      jason_maranto
                      Bonzai3D contains a native "meshing" feature that does exactly this -- the idea is you simply tell it how large you would like the squares to be (in whatever units you are working in) and it will re-create the meshed faces.
                      That is a really nice feature of their package -- other nice features are: they have much better import and export capabilities and Nurbs tools built in... all for the same price as Sketchup Pro. I hope Sketchup is feeling the pressure applied by Bonzai3D and will begin to more seriously develop similar tools for Pro users.
                      Best,
                      Jason.
                        Actually there is a way for Tgi3D Amorph to subdivide with more regular rectangles (I mean closer to squares or whatever you need) just divide the bounding edges first - then it will use those endpoints as well to upsample the face.
                        But then it's again some manual fiddling around with the edges/faces...
                        Divided longer edges
                        Resulting subdivision - x3
                          So, a tool that draws Divided Edges ๐Ÿ˜‰
                            Well, not really. A tool that subdivides faces with rectangle as close to squares as possible.
                            I would not connect it to a certain material however (as opposed to the original request) One may want to slightly bevel some edges - those should only be subdivided in the longer direction of the very narrow rectangles (those are not favourable at all).
                              Also, look at Pixero's excellent mini-tut over the Thea Forums about modelling a hedge. In this case, some similar subdivision would be a god-send.
                              http://www.thearender.com/forum/viewtopic.php?p=42727#p42727
                              • srxS Offline
                                srx
                                Maybe this plugin could work like this:
                                1 Take the regular mesh Gai presented.
                                2 Align and project it to every selected face (with filter for selecting faces with the same material ๐Ÿ˜„
                                www.saurus.rs
                                • EarthMoverE Offline
                                  EarthMover
                                  How about using Soap Skin & Bubble, but just using the "skin" button to generate the even subdivisions? It works well as a subdivision skinning tool. Double click the face, hit skin, set the subdivisions, let it process, then explode the group.
                                  Content Creator at Skapeup
                                  • srxS Offline
                                    srx
                                    Who could thought of this? Interesting method. It riches the half of the job.
                                    Still is not automatic for more than one differently oriented faces.
                                    www.saurus.rs
                                      Yes, SSB would do the trick - at least the "manual subdivision part".
                                      With a hedge like in Pixero's tutorial, it could still be laborious.
                                      • sdmitchS Offline
                                        sdmitch
                                        srx, The attached plugin is my attempt to automate the sub-dividing of faces with a given material. For reasons I have yet to figure out, it sometimes has a problem around window openings if the grid happens to fall a certain way. I hope you find it helpful.
                                        sub-divides face with given material
                                        http://sdmitch.blogspot.com/
                                          EarthMover
                                          Thanks Sam. Good tool. It seems you have to select all faces by material and then also choose the material in the drop down for it to work properly. Might make more sense to just have it either divide the selected faces, or allow you to run the plugin with no selection and then divide by material. Current method seems a tad redundant. Either way it is a time saver and much appreciated! ๐Ÿ‘
                                          • srxS Offline
                                            srx
                                            Thank you Sam!
                                            I love this forum.
                                            The plugin should have its own topic. It's very useful.
                                            www.saurus.rs
                                            • 1 / 2
