    Subdividing faces for displacement plugin
    25 Posts 8 Posters 5.9k Views 8 Watching
      So, a tool that draws Divided Edges ๐Ÿ˜‰
        Well, not really. A tool that subdivides faces with rectangle as close to squares as possible.
        I would not connect it to a certain material however (as opposed to the original request) One may want to slightly bevel some edges - those should only be subdivided in the longer direction of the very narrow rectangles (those are not favourable at all).
          Also, look at Pixero's excellent mini-tut over the Thea Forums about modelling a hedge. In this case, some similar subdivision would be a god-send.
          http://www.thearender.com/forum/viewtopic.php?p=42727#p42727
          • srxS Offline
            srx
            Maybe this plugin could work like this:
            1 Take the regular mesh Gai presented.
            2 Align and project it to every selected face (with filter for selecting faces with the same material ๐Ÿ˜„
            www.saurus.rs
            • EarthMoverE Offline
              EarthMover
              How about using Soap Skin & Bubble, but just using the "skin" button to generate the even subdivisions? It works well as a subdivision skinning tool. Double click the face, hit skin, set the subdivisions, let it process, then explode the group.
              Content Creator at Skapeup
              • srxS Offline
                srx
                Who could thought of this? Interesting method. It riches the half of the job.
                Still is not automatic for more than one differently oriented faces.
                www.saurus.rs
                  Yes, SSB would do the trick - at least the "manual subdivision part".
                  With a hedge like in Pixero's tutorial, it could still be laborious.
                  • sdmitchS Offline
                    sdmitch
                    @srx said:
                    I was thinking about more automotive work flow.
                    1 Input - one or more materials (for example stone)
                    2 Output - All the faces with stone material applied are subdivided evenly (more or less). This is what displacement needs.
                    This is kind of reversed "remove collinear edges" command - Add collinear edges ๐Ÿ˜„
                    srx, The attached plugin is my attempt to automate the sub-dividing of faces with a given material. For reasons I have yet to figure out, it sometimes has a problem around window openings if the grid happens to fall a certain way. I hope you find it helpful.
                    sub-divides face with given material
                    http://sdmitch.blogspot.com/
                      EarthMover
                      Thanks Sam. Good tool. It seems you have to select all faces by material and then also choose the material in the drop down for it to work properly. Might make more sense to just have it either divide the selected faces, or allow you to run the plugin with no selection and then divide by material. Current method seems a tad redundant. Either way it is a time saver and much appreciated! ๐Ÿ‘
                      • srxS Offline
                        srx
                        Thank you Sam!
                        I love this forum.
                        The plugin should have its own topic. It's very useful.
                        www.saurus.rs
                          This is super, Sam. ๐Ÿ‘ Thanks a bunch (still before trying...)
                          Could you also post the plugin in the Plugins forum, with the [Plugin] tag? That's how the plugin index is being updated.
                          (And maybe instead of the plugin attached here directly, just a link to that post. See, folks are already requesting changes so I can imagine some further versions).
                          And thanks again! โ˜€
                          • N Offline
                            notareal
                            Drape Cpoints can also be used for creating evenly subdivided mesh for displacement. Works well with ground, roofs or similar objects. http://forums.sketchucation.com/viewtopic.php?f=323&t=21379
                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                              True! ๐Ÿ‘
                              (Although for completely vertical faces like walls, it is not the best tool)
                              • sdmitchS Offline
                                sdmitch
                                EarthMover you are right in that it is a bit redundent to have to select and specify material and is a simple change but wasn't sure if the sub-divided faces would be left in the original model or moved so selecting avoided the re-dividing of faces. Also, I didn't want to assume that every face with a given material in the model was to be sub-divided.
                                srx, what changes if any would you like to be made?
                                • srxS Offline
                                  srx
                                  Here is the tutorial ๐Ÿ˜„
                                  http://forums.sketchucation.com/viewtopic.php?f=18&t=37707&p=332802#p332802
                                  www.saurus.rs
