    Subdividing faces for displacement plugin
    25 Posts 8 Posters 5.5k Views 8 Watching
      This is super, Sam. πŸ‘ Thanks a bunch (still before trying...)
      Could you also post the plugin in the Plugins forum, with the [Plugin] tag? That's how the plugin index is being updated.
      (And maybe instead of the plugin attached here directly, just a link to that post. See, folks are already requesting changes so I can imagine some further versions).
      And thanks again! β˜€
      • N Offline
        notareal
        Drape Cpoints can also be used for creating evenly subdivided mesh for displacement. Works well with ground, roofs or similar objects. http://forums.sketchucation.com/viewtopic.php?f=323&t=21379
          True! πŸ‘
          (Although for completely vertical faces like walls, it is not the best tool)
          • sdmitchS Offline
            sdmitch
            EarthMover you are right in that it is a bit redundent to have to select and specify material and is a simple change but wasn't sure if the sub-divided faces would be left in the original model or moved so selecting avoided the re-dividing of faces. Also, I didn't want to assume that every face with a given material in the model was to be sub-divided.
            srx, what changes if any would you like to be made?
            http://sdmitch.blogspot.com/
            • srxS Offline
              srx
              Here is the tutorial πŸ˜„
              http://forums.sketchucation.com/viewtopic.php?f=18&t=37707&p=332802#p332802
              www.saurus.rs
              • 2 / 2
