    Subdividing faces for displacement plugin
    25 Posts 8 Posters 6.6k Views 8 Watching
    • GaieusG
      Nope. As I said, these plugins divide each bounding edge equally. So there are no squares but longish rectangles only.
        I see ๐Ÿ‘
        • jason_marantoJ
          jason_maranto
          Bonzai3D contains a native "meshing" feature that does exactly this -- the idea is you simply tell it how large you would like the squares to be (in whatever units you are working in) and it will re-create the meshed faces.
          That is a really nice feature of their package -- other nice features are: they have much better import and export capabilities and Nurbs tools built in... all for the same price as Sketchup Pro. I hope Sketchup is feeling the pressure applied by Bonzai3D and will begin to more seriously develop similar tools for Pro users.
          Best,
          Jason.
          • GaieusG
            Actually there is a way for Tgi3D Amorph to subdivide with more regular rectangles (I mean closer to squares or whatever you need) just divide the bounding edges first - then it will use those endpoints as well to upsample the face.
            But then it's again some manual fiddling around with the edges/faces...
            Divided longer edges
            Resulting subdivision - x3
              So, a tool that draws Divided Edges ๐Ÿ˜‰
              • GaieusG
                Well, not really. A tool that subdivides faces with rectangle as close to squares as possible.
                I would not connect it to a certain material however (as opposed to the original request) One may want to slightly bevel some edges - those should only be subdivided in the longer direction of the very narrow rectangles (those are not favourable at all).
                • GaieusG
                  Also, look at Pixero's excellent mini-tut over the Thea Forums about modelling a hedge. In this case, some similar subdivision would be a god-send.
                  http://www.thearender.com/forum/viewtopic.php?p=42727#p42727
                  • srxS
                    srx
                    Maybe this plugin could work like this:
                    1 Take the regular mesh Gai presented.
                    2 Align and project it to every selected face (with filter for selecting faces with the same material ๐Ÿ˜„
                    www.saurus.rs
                    • EarthMoverE
                      EarthMover
                      How about using Soap Skin & Bubble, but just using the "skin" button to generate the even subdivisions? It works well as a subdivision skinning tool. Double click the face, hit skin, set the subdivisions, let it process, then explode the group.
                      Content Creator at Skapeup
                      • srxS
                        srx
                        Who could thought of this? Interesting method. It riches the half of the job.
                        Still is not automatic for more than one differently oriented faces.
                        www.saurus.rs
                        • GaieusG
                          Yes, SSB would do the trick - at least the "manual subdivision part".
                          With a hedge like in Pixero's tutorial, it could still be laborious.
                          • sdmitchS
                            sdmitch
                            @srx said:
                            I was thinking about more automotive work flow.
                            1 Input - one or more materials (for example stone)
                            2 Output - All the faces with stone material applied are subdivided evenly (more or less). This is what displacement needs.
                            This is kind of reversed "remove collinear edges" command - Add collinear edges ๐Ÿ˜„
                            srx, The attached plugin is my attempt to automate the sub-dividing of faces with a given material. For reasons I have yet to figure out, it sometimes has a problem around window openings if the grid happens to fall a certain way. I hope you find it helpful.
                            sub-divides face with given material
                            http://sdmitch.blogspot.com/
                            • EarthMoverE
                              EarthMover
                              Thanks Sam. Good tool. It seems you have to select all faces by material and then also choose the material in the drop down for it to work properly. Might make more sense to just have it either divide the selected faces, or allow you to run the plugin with no selection and then divide by material. Current method seems a tad redundant. Either way it is a time saver and much appreciated! ๐Ÿ‘
                              • srxS
                                srx
                                Thank you Sam!
                                I love this forum.
                                The plugin should have its own topic. It's very useful.
                                www.saurus.rs
                                • GaieusG
                                  This is super, Sam. ๐Ÿ‘ Thanks a bunch (still before trying...)
                                  Could you also post the plugin in the Plugins forum, with the [Plugin] tag? That's how the plugin index is being updated.
                                  (And maybe instead of the plugin attached here directly, just a link to that post. See, folks are already requesting changes so I can imagine some further versions).
                                  And thanks again! โ˜€
                                  • N
                                    notareal
                                    Drape Cpoints can also be used for creating evenly subdivided mesh for displacement. Works well with ground, roofs or similar objects. http://forums.sketchucation.com/viewtopic.php?f=323&t=21379
                                    • GaieusG
                                      True! ๐Ÿ‘
                                      (Although for completely vertical faces like walls, it is not the best tool)
                                      • sdmitchS
                                        sdmitch
                                        EarthMover you are right in that it is a bit redundent to have to select and specify material and is a simple change but wasn't sure if the sub-divided faces would be left in the original model or moved so selecting avoided the re-dividing of faces. Also, I didn't want to assume that every face with a given material in the model was to be sub-divided.
                                        srx, what changes if any would you like to be made?
                                        • srxS
                                          srx
                                          Here is the tutorial ๐Ÿ˜„
                                          http://forums.sketchucation.com/viewtopic.php?f=18&t=37707&p=332802#p332802
                                          www.saurus.rs
