    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] TextureTools
    106 Posts 34 Posters 103.7k Views 34 Watching
      driven
      @tig said:
      feedback please - especially MAC users as I'm not sure about the key-codes...
      KeyCodes UP, Down, Left, Right work on 10.5.8, and I changed KSHIFT = VK_SHIFT to get shift to work
      I'll read the instructions now that I've worked out that you have to apply material to the front face for it to work at all.
      Is an alert possible for back face materials, I was trying to adjust texture on a LiveIvy skp and some are front face and some back face and I couldn't figure why TR was working intermittently.
      I'll try and get the correct KeyCode for Shift, but Jims script is throwing an error at the moment and I need sleep.
      great stuff, again
      john
      • massimoM Offline
        massimo Moderator
        @tig said:
        @massimo said:
        A detail: the first time you start the "nudge" and the "shunt" tools you are obliged to input an increment because if you confirm the default number by just pressing "Ok" they don't work.
        I'll look at it... ๐Ÿ˜•
        EDIT:
        I recheck and it works fine... ๐Ÿ˜•
        I have cm and yes it's the latest version, so i think it's not a matter of small lengths. I think that the culprit is the "." (just noticed the dot). So the default "1.0" should be "1,0" for me. Here you have the ruby console anyway.
        Error; #<ArgumentError; Cannot convert "1.0" to Length>
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/TextureRotate.rb;282;in `to_l'
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/TextureRotate.rb;282;in `reset'
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/TextureRotate.rb;276;in `activate'
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/TextureRotate.rb;410;in `select_tool'
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/TextureRotate.rb;410;in `call'
        EDIT
        IF you want to have a default find @@u, @@v and @@d values near the start of the two tools class initialize and change the numbers there
        Changed "1.0" to "1,0" and now seems to work fine. ๐Ÿ‘
        EDIT 2
        Tried to change also the "angle" default parameter to "90,0" but it doesn't work. So now I have the "rotate" which works with "dot" and the "shunt+nudge" with "comma". ๐Ÿ˜•
          Jean-Luc Clauss
          Nice tool for geomodeling.
          Thank you so much Tig !
          Auteur de guides et de mรฉmos sur SketchUp aux รฉditions ENI
          http://archi-com21.blogspot.fr/
            Massimo
            I hadn't anticipated you weird Eurpoeans using a ',' as a decimal point rather than a sensible '.' ๐Ÿ˜’
            I can easily trap that in the code... I'll release an update later today - it should also have new tools added - TextureScale and TextureTweak... ๐Ÿ˜„
            • V Offline
              vidy
              Wooow.. like this TIG, thank you..
              my wish, hopefully it could do also on the complex shape surface like sphere or cylinder.. ๐ŸŽ‰
              regards,
              still so much to learn..
                Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                New tools have been added - TextureScale & TextureTweak [Scale by Arrows], and TextureAdjust [Rotate by Arrows]. Some button png files have been adjusted.
                'Locale' use of a ',' instead of a '.' as a decimal-point now works in all dialogs.
                Please read the usage note for each tool...
                Feedback please...
                • massimoM Offline
                  massimo Moderator
                  Wonderful. ๐Ÿ˜ฎ ๐Ÿ‘
                  A little issue is that now i have to do something like this when input values:
                  rotate-->dot
                  adjust-->dot
                  shunt-->comma
                  nudge-->comma
                  scale-->dot
                  tweak-->dot
                  While in SU i use always comma.
                  • OxerO Offline
                    Oxer
                    Thanks TIG, it works fine on Mac, only one thing the dot and comma don't works on all tools.
                    [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                      rotate-->dot
                      adjust-->dot
                      shunt-->comma
                      nudge-->comma
                      scale-->dot
                      tweak-->dot
                      Massimo [& Oxer]
                      What's your 'locale' ?
                      How do you normally input 'decimal-points' ?
                      In the UK/US it's 1.234 and I know in EU etc its [perversely] 1,234
                      The rotate/scale tools take 'float' numbers because angles and scaling are always in that format - the 'decimal-point' is determined by the system setup/locale not by me... 'I think 'floats' always use a '.' ??
                      The shunt/nudge tool takes a 'string' as its input since the user might type '10mm' or '1"' irrespective of their current units, and if they type '1' and their current units are 'cm' it is taken as '1cm', using the API's .to_l method. When the user enters a decimal-point it should be in the format that is determined by the system setup/locale not by me... So '1.234' or '1,234' - however I'm amazed that the two types of input are handled different.
                      Can you do a test in the Ruby Console for me... type these [exactly as they appear here] and report the result:
                      1.23.class 1,23.class 1.23.to_l 1,23.to_l '1.23'.to_l '1,23'.to_l
                      Depending on your feedback I COULD try trap it to change the input for the 'string' type so if you entered '1.23' and it couldn't be made into a length in length='1.23'.to_l then it'd try length='1.23'.tr('.',',').to_l - that way all of these tools would expect you always to use a '.' BUT it would substitute a ',' if your system needed it...
                      The code to swap is
                        u=u.to_l
                        v=v.to_l
                      which becomes
                        begin
                          u=u.to_l
                        rescue
                          u=u.tr('.', ',').to_l
                        begin
                          v=v.to_l
                        rescue
                          v=v.tr('.', ',').to_l
                      AND then
                        @d=@@nudge.to_l
                      which becomes
                        begin
                          @d=@@nudge.to_l
                        rescue
                          @d=@@nudge.tr('.', ',').to_l
                      ๐Ÿ’ญ
                      • massimoM Offline
                        massimo Moderator
                        Well TIG in SU it's always comma or semicolon (for example when drawing a rectangle) for me, even the plugins, while in CAD, for example, it's always dot...
                        Anyway here is what i get in the ruby console:
                        1.23.class
                        Float
                          1.23.class
                          > Float
                          I'd like the whole list please ?
                          I know in EU etc in the SKP's UI the '.' swaps with the ',' and then the ',' with the ';' BUT in the Ruby API I must always use a '.' as the decimal-separator, ',' as the list-separator and ';' as a line-break...
                          However I'd have expected that the SUp UI would seamlessly swap float '.' for ',' when displayed inputed in a UI.inputbox() to suit the locale, as it seems to take ',' in strings to convert to 'lengths' ??
                          • massimoM Offline
                            massimo Moderator
                            I've copied and pasted ALL the text you posted, sorry... ๐Ÿ˜ณ ๐Ÿ˜’
                            Here you have the results of every single line
                            1.23.class
                            Float
                            1,23.class
                            Error; #<SyntaxError; (eval);894; compile error
                            (eval);894; syntax error
                            1,23.class
                            (eval);894
                            1.23.to_l
                            1.23
                            1,23.to_l
                            1,23.to_l
                            (eval);894
                            '1.23'.to_l
                            Error; #<ArgumentError; (eval);894;in `to_l'; Cannot convert "1.23" to Length>
                            (eval);894
                            '1,23'.to_l
                            0.484251968503937
                            • OxerO Offline
                              Oxer
                              Hi TIG,
                              I had probe to type the text in Ruby Console and this the result:
                              I'm in Spain (EU) and i use metric units.
                                So, as I suspected...
                                I'll reissue a trapped version that will take '.' or ',' as the decimal-separator in the inputbox for every tool, BUT it will if it's a string value it'll convert it to ',' to suit your locale and make a length from it if it has to... entering a number with a ',' it WILL work without failing [IF the locale supports] BUT it'll convert it back into a '.' when you OK the dialog...
                                Watch for an update...
                                • jgbJ Offline
                                  jgb
                                  Ah yes, A period is as important to a programmer as it is to his girlfriend. ๐Ÿคฃ
                                  jgb
                                  • N Offline
                                    notareal
                                    @tig said:
                                    Massimo
                                    ๐Ÿ˜ฒ ...waiting for the fix.
                                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                      Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                                      Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code, 'behind the scenes'.
                                      Feedback please...
                                      • broomstickB Offline
                                        broomstick
                                        Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code behind the scenes.
                                        Feedback please...
                                        Just tried it, win7 64 bit skp 8... works fine and I must say this is one of the best plugins ever made!!!
                                          driven
                                          Hi TIG,
                                          all functionality working very well on the Mac, except toolbar tooltips.
                                          They work if I put the icons in the custom toolbar but not on the standard, floating toolbar.
                                          not a big issue here, just thought I'd mention it.
                                          john
                                          • massimoM Offline
                                            massimo Moderator
                                            Here's v1.5 viewtopic.php?p=329765#p329765...
                                            Perfect! ๐Ÿ˜„
                                            • 6
                                            • 2 / 6
