    Weld doesn't weld once more
    14 Posts 8 Posters 848 Views 8 Watching
      Larsen
      Hi to all
      Please, I struggle with an "unweldable" curve.
      Any suggestions.
      Weld doesnt weld.skp
      [Every form of thinking perish by excess of its basic principles.
        They welded fine for me.
        • boofredlayB Offline
          boofredlay
          Have you installed Recurve.rb?
          Alan had a similar problem not getting Weld.rb to work in this thread: http://forums.sketchucation.com/viewtopic.php?p=324775#p324775
          I still wonder if there is a conflict or not.
          • Alan FraserA Offline
            Alan Fraser
            Weld started working again later, in another model, without me making any changes. But then Repair Broken Lines didn't work on a model yesterday. It reported lots of lines fixed....but it was lying. I had Model Info open and nothing changed. Something funny going on under the hood.
            3D Figures
              Larsen
              Thanks for your reply.
              I have tested some similar curves and all weld/recurve but this one doesn't.
              Thanks anyway.
              • mitcorbM Offline
                mitcorb
                Check out ThomThom's Vertex Tools? or Cleanup?
                Edit: Caveat lector. 😄
                • mitcorbM Offline
                  mitcorb
                  As for the illustration: Did anybody check for extremely tiny forks or gaps along the "curve"?
                    I didn't find any forks or gaps and Weld worked just fine for me the first time I tried it on those edges.
                      • mitcorbM Offline
                        mitcorb
                        Then this pushes the problem to either a faulty installation of the plugin, a conflicting other plugin, or an OS update, or other change in the system?
                          I've a feeling we've a troublesome script on our hands. There's been a few issues of late on numerous threads.
                            Larsen
                            Weld is an excellent plugin and I use it permanently. I think that something occur in the plugin folder, some names became blue. I think I will reinstall SU ultimately xp.
                            Thanks for your support.
                              Larsen
                              Hi to all,
                              In fact the problem was an alternate usage of weld and recurve plugins.
                              I have to make a choise btw them.
                              1000 excuses for the Bothering.
                                Jim57
                                I sometimes have problems too. I wrote them off to not restarting (Mac) often enough, because that often helps.
                                Jim
