    Weld doesn't weld once more
    14 Posts 8 Posters 975 Views 8 Watching
      Larsen
      Thanks for your reply.
      I have tested some similar curves and all weld/recurve but this one doesn't.
      Thanks anyway.
      [Every form of thinking perish by excess of its basic principles.
      • mitcorbM Offline
        mitcorb
        Check out ThomThom's Vertex Tools? or Cleanup?
        Edit: Caveat lector. 😄
        • mitcorbM Offline
          mitcorb
          As for the illustration: Did anybody check for extremely tiny forks or gaps along the "curve"?
            I didn't find any forks or gaps and Weld worked just fine for me the first time I tried it on those edges.
              • mitcorbM Offline
                mitcorb
                Then this pushes the problem to either a faulty installation of the plugin, a conflicting other plugin, or an OS update, or other change in the system?
                • Rich O BrienR Online
                  I've a feeling we've a troublesome script on our hands. There's been a few issues of late on numerous threads.
                    Larsen
                    Weld is an excellent plugin and I use it permanently. I think that something occur in the plugin folder, some names became blue. I think I will reinstall SU ultimately xp.
                    Thanks for your support.
                      Larsen
                      Hi to all,
                      In fact the problem was an alternate usage of weld and recurve plugins.
                      I have to make a choise btw them.
                      1000 excuses for the Bothering.
                        Jim57
                        I sometimes have problems too. I wrote them off to not restarting (Mac) often enough, because that often helps.
                        Jim
