    Vertex to points
    7 Posts 5 Posters 569 Views 5 Watching
      Larsen
      Hi to all
      Is there any way to transform an exploded curve and conserve only the vertex in the forme of points.
      Thanks.
      [Every form of thinking perish by excess of its basic principles.
      • jeff hammondJ Offline
        jeff hammond
        yeah, use thomthom's guide tools
        404 Not Found
        (forums.sketchucation.com)
        1. select curve
        2. explode curve
        3. plugins-> guide tools -> CPoint at edge-edge intersection
        4. delete
        dotdotdot
        • simon le bonS Offline
          simon le bon
          Hoops Jeff is quicker _ and once again a ThomThom tool ๐Ÿ˜‰
          Hi Larsen,
          Very easy!
          use ThomThom Selection Toys
          (an absolute must have!)
          Select everything you want to remove(curves,faces,lines etc..) including the construction points you want to keep, then context menu (right clic) : "Deselect" sub-menu"construction points". This way everything is selected but the construction points. Now simply delete this resultant selection.
          ๐Ÿ˜‰ simon.
            A multi-enries glossary of all plugins is a necessity to avoid such idiot questions
            Not very easy, there are soon some more 1500 plugins ๐Ÿ˜ฎ
            So it's more easy to ask someone something particular! โ˜€
              Larsen try... Capture.PNG + a search of that page for key words..., coupled with a Plugins forum advanced search... ๐Ÿ˜•
                Larsen
                Thanks TIG for your information. Your modesty defeat your generosity.
                  Larsen
                  Hi to All
                  Thanks Jeffe,
                  Thanks Simon
                  Really some Rubies are well-hidden. A multi-entries glossary of all plugins is a necessity to avoid such idiot questions. I am not a database specialist but I think it's feasable.
                  Of course I will be fired (By who knows) for saying that.
                  Thanks ThomThom for your generosity.
