    [Plugin] SurfaceGen (0.9.0b) — 28 April 2012
    69 Posts 25 Posters 64.8k Views 25 Watching
      Diggsey
      Unfortunately, I don't think there's a way to give focus back to SketchUp from ruby. (Someone correct me if I'm wrong!)
        Jim
        I don't think so either, and I realize a small change in workflow is all that's required - but as the saying goes "old habits die hard." No worries.
          If you pick a surfacegen-entity the surfacegen-dialog appears.
          Minimize that surfacegen-dialog.
          The focus will then return to the SKP window.
          So now you can use shortcuts etc to Move the selected entity etc.
          Restore the surfacegen-dialog to change the surfacegen-entity's settings... 🤓
          • PixeroP Offline
            Pixero
            @diggsey said:
            What exactly do you mean by noise? Surely just adding (rand-0.5) will put noise on the graph?
            With random numbers there is no relationship between a given random and the next random.
            Noise however, produces a naturally ordered smooth sequence of numbers with makes it more useful when creating surfaces or textures. (Think surface displacement to create waves and clouds.)
            Here's a few links that explain it better than I can:
            http://en.wikipedia.org/wiki/Simplex_noise
            http://www.noisemachine.com/talk1/
            http://webstaff.itn.liu.se/~stegu/simplexnoise/simplexnoise.pdf
            • PixeroP Offline
              Pixero
              Instant roof. 😄
                d12dozr
                @diggsey said:
                Just uploaded a fairly major update to the first post!
                @d12dozr
                Helpful error message are now shown when an expression is invalid.
                Thank you...helps me take my baby steps 😆
                One thing...when I start a new SU file from File -> New, the dialog for SurfaceGen doesn't pop up. It does work if I close SU down completely and restart. I can draw the boundary box, but then cannot do anything else. I opened the Ruby Console while opening a new file, but didn't get any error messages.
                http://goo.gl/f7ooYh
                  robert111
                  nice roof Pixero
                  but your fonction is not visible.
                  • PixeroP Offline
                    Pixero
                    -abs(x)+sin(8*y)
                    The rest I think you can see in the picture.
                    • OxerO Offline
                      Oxer
                      Thanks Diggsey for this incredible plugin! 👍
                      I have translated the plugin to spanish language.
                      SurfaceGen v0.8 spanish version
                      http://www.oxervision.blogspot.com/
                      • N Offline
                        noteman8.0
                        nice plugin....THX
                          LannorMov
                          Me gusta este pluguin,se ve interesante, pero lo veo un poco complicado y de poco uso en Arquitectura, no sé si en otras carreras sea tan útil. Voy a buscarle una función. gracias Oxer.
                          • 66searcher6 Offline
                            66searcher
                            @Diggsey
                            👍 great plugin ! 👍 great job !
                            http://hamidtoliat.deviantart.com/
                              LannorMov
                              El otro dia dije "Gracias Oxer" cuando en realidad quería decir "Gracias Diggsey"
                              Disculpa.
                                66searcher
                                a test :
                                  justinplunkett
                                  I feel like a 5 year old. The geometric forms created are gorgeous and I haven't the faintest idea how to use this.
                                    make.GQ.china
                                    👍 Thank you very much! Good plugin
                                    • H Offline
                                      Heven7_floor
                                      Thanks you very great plugin 👍 👍
                                        boilingsnow
                                        Very cool plugin!
                                        But a progress bar could be very helpful. Because I 've installed it and by performing the plugin it seems to take hours to generate a surface and I don't know if it is really working!
                                        I've waited for more than 25 minutes for a simple eqation so I have to give up finally...
                                        In other words, I can't get it work in my sketchup 8.
                                        • I Offline
                                          imabzeous
                                          a very nice plugin, ( as i have seen only in pics and shapes that you have created) but i don't understand where can i get equations for it? i want to make some fractal geometry but when i applied the equation it wont work. so can any body help me with this equation thing more..
                                          and thank you
                                            boilingsnow
                                            @boilingsnow said:
                                            Very cool plugin!
                                            I figured out that SurfaceGen has a conflict with another plugin calls 'Modelfuction'.
                                            If you get Modelfuction installed in your sketchup, you can see the pop-up window by applying Surfacegen, but it will not create any surface.
                                            I have uninstalled Modelfunction now and SurfaceGen works well!
                                            By the way this is really a awesome plugin. So it would be perfect if the author can get rid of the conflict with other plugins...
                                            • 3 / 4
