    [Plugin] SurfaceGen (0.9.0b) — 28 April 2012
    69 Posts 25 Posters 64.7k Views 25 Watching
      driven
      BTW.. the varying size of content seen by jim is most likely due to your using [ font-size: 8pt; ] as although 1px=0.75pt different browsers treat pt oddly,
      with safari, in SU, on my mac 8pt is reading as 8px and everything fits if a bit small.
      • N Offline
        notareal
        Got some inspiration from http://abdelhamid394.blogspot.com/
        • PixeroP Offline
          Pixero
          This is very cool.
          Two questions:
          Is there any noise available? If not that would be a great addition.
          I've tried with rand but that isn't noise. 😞
          A few links to good sites with functions and equations for surfaces would also help getting up to speed.
            Diggsey
            I've updated the first post with version 0.8.
            @Pixero
            What exactly do you mean by noise? Surely just adding (rand-0.5) will put noise on the graph?
              Jim
              Thanks, Diggsey.
              Just a minor annoyance. Since the dialog steals the focsus, whenever I select a Surface, my SU shortcuts don't work. For example, select the Surface to move it - press the 'm' shortcut to Move it - can't Move it because the dialog got the keypress. 😞
                Diggsey
                Unfortunately, I don't think there's a way to give focus back to SketchUp from ruby. (Someone correct me if I'm wrong!)
                  Jim
                  I don't think so either, and I realize a small change in workflow is all that's required - but as the saying goes "old habits die hard." No worries.
                    If you pick a surfacegen-entity the surfacegen-dialog appears.
                    Minimize that surfacegen-dialog.
                    The focus will then return to the SKP window.
                    So now you can use shortcuts etc to Move the selected entity etc.
                    Restore the surfacegen-dialog to change the surfacegen-entity's settings... 🤓
                    • PixeroP Offline
                      Pixero
                      With random numbers there is no relationship between a given random and the next random.
                      Noise however, produces a naturally ordered smooth sequence of numbers with makes it more useful when creating surfaces or textures. (Think surface displacement to create waves and clouds.)
                      Here's a few links that explain it better than I can:
                      http://en.wikipedia.org/wiki/Simplex_noise
                      http://www.noisemachine.com/talk1/
                      http://webstaff.itn.liu.se/~stegu/simplexnoise/simplexnoise.pdf
                      • PixeroP Offline
                        Pixero
                        Instant roof. 😄
                          d12dozr
                          @diggsey said:
                          Just uploaded a fairly major update to the first post!
                          @d12dozr
                          Helpful error message are now shown when an expression is invalid.
                          Thank you...helps me take my baby steps 😆
                          One thing...when I start a new SU file from File -> New, the dialog for SurfaceGen doesn't pop up. It does work if I close SU down completely and restart. I can draw the boundary box, but then cannot do anything else. I opened the Ruby Console while opening a new file, but didn't get any error messages.
                          http://goo.gl/f7ooYh
                            robert111
                            nice roof Pixero
                            but your fonction is not visible.
                            • PixeroP Offline
                              Pixero
                              -abs(x)+sin(8*y)
                              The rest I think you can see in the picture.
                              • OxerO Offline
                                Oxer
                                Thanks Diggsey for this incredible plugin! 👍
                                I have translated the plugin to spanish language.
                                SurfaceGen v0.8 spanish version
                                • N Offline
                                  noteman8.0
                                  nice plugin....THX
                                    LannorMov
                                    Me gusta este pluguin,se ve interesante, pero lo veo un poco complicado y de poco uso en Arquitectura, no sé si en otras carreras sea tan útil. Voy a buscarle una función. gracias Oxer.
                                    • 66searcher6 Offline
                                      66searcher
                                      @Diggsey
                                      👍 great plugin ! 👍 great job !
                                      http://hamidtoliat.deviantart.com/
                                        LannorMov
                                        El otro dia dije "Gracias Oxer" cuando en realidad quería decir "Gracias Diggsey"
                                        Disculpa.
                                          66searcher
                                          a test :
                                            justinplunkett
                                            I feel like a 5 year old. The geometric forms created are gorgeous and I haven't the faintest idea how to use this.
                                            • 3 / 4
