    [Plugin] SurfaceGen (0.9.0b) — 28 April 2012
    69 Posts 25 Posters 65.2k Views 25 Watching
      Jim
      Thanks, Diggsey.
      Just a minor annoyance. Since the dialog steals the focsus, whenever I select a Surface, my SU shortcuts don't work. For example, select the Surface to move it - press the 'm' shortcut to Move it - can't Move it because the dialog got the keypress. 😞
        Diggsey
        Unfortunately, I don't think there's a way to give focus back to SketchUp from ruby. (Someone correct me if I'm wrong!)
          Jim
          I don't think so either, and I realize a small change in workflow is all that's required - but as the saying goes "old habits die hard." No worries.
            If you pick a surfacegen-entity the surfacegen-dialog appears.
            Minimize that surfacegen-dialog.
            The focus will then return to the SKP window.
            So now you can use shortcuts etc to Move the selected entity etc.
            Restore the surfacegen-dialog to change the surfacegen-entity's settings... 🤓
            • PixeroP Offline
              Pixero
              @diggsey said:
              What exactly do you mean by noise? Surely just adding (rand-0.5) will put noise on the graph?
              With random numbers there is no relationship between a given random and the next random.
              Noise however, produces a naturally ordered smooth sequence of numbers with makes it more useful when creating surfaces or textures. (Think surface displacement to create waves and clouds.)
              Here's a few links that explain it better than I can:
              http://en.wikipedia.org/wiki/Simplex_noise
              http://www.noisemachine.com/talk1/
              http://webstaff.itn.liu.se/~stegu/simplexnoise/simplexnoise.pdf
              • PixeroP Offline
                Pixero
                Instant roof. 😄
                  d12dozr
                  @diggsey said:
                  Just uploaded a fairly major update to the first post!
                  @d12dozr
                  Helpful error message are now shown when an expression is invalid.
                  Thank you...helps me take my baby steps 😆
                  One thing...when I start a new SU file from File -> New, the dialog for SurfaceGen doesn't pop up. It does work if I close SU down completely and restart. I can draw the boundary box, but then cannot do anything else. I opened the Ruby Console while opening a new file, but didn't get any error messages.
                  http://goo.gl/f7ooYh
                    robert111
                    nice roof Pixero
                    but your fonction is not visible.
                    • PixeroP Offline
                      Pixero
                      -abs(x)+sin(8*y)
                      The rest I think you can see in the picture.
                      • OxerO Offline
                        Oxer
                        Thanks Diggsey for this incredible plugin! 👍
                        I have translated the plugin to spanish language.
                        SurfaceGen v0.8 spanish version
                        • N Offline
                          noteman8.0
                          nice plugin....THX
                            LannorMov
                            Me gusta este pluguin,se ve interesante, pero lo veo un poco complicado y de poco uso en Arquitectura, no sé si en otras carreras sea tan útil. Voy a buscarle una función. gracias Oxer.
                            • 66searcher6 Offline
                              66searcher
                              @Diggsey
                              👍 great plugin ! 👍 great job !
                              http://hamidtoliat.deviantart.com/
                                LannorMov
                                El otro dia dije "Gracias Oxer" cuando en realidad quería decir "Gracias Diggsey"
                                Disculpa.
                                  66searcher
                                  a test :
                                    justinplunkett
                                    I feel like a 5 year old. The geometric forms created are gorgeous and I haven't the faintest idea how to use this.
                                      make.GQ.china
                                      👍 Thank you very much! Good plugin
                                      • H Offline
                                        Heven7_floor
                                        Thanks you very great plugin 👍 👍
                                          boilingsnow
                                          Very cool plugin!
                                          But a progress bar could be very helpful. Because I 've installed it and by performing the plugin it seems to take hours to generate a surface and I don't know if it is really working!
                                          I've waited for more than 25 minutes for a simple eqation so I have to give up finally...
                                          In other words, I can't get it work in my sketchup 8.
                                          • I Offline
                                            imabzeous
                                            a very nice plugin, ( as i have seen only in pics and shapes that you have created) but i don't understand where can i get equations for it? i want to make some fractal geometry but when i applied the equation it wont work. so can any body help me with this equation thing more..
                                            and thank you
                                            • 3 / 4
