    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • G
      gaonirico
      I uninstalled the previous version and installed the update but follows without functioning
      • P
        Pierreden
        Any messages in the ruby console?
        • G
          gaonirico
          Error: #<IOError: Invalid component file>
          C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
          C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
          C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
          • P
            Pierreden
            Try the new file (0.5.2) 👍
            • G
              gaonirico
              Yeah, it working fine now... Thanks Pierreden, million thanks
              • G
                gaonirico
                The proof that works well:
                • G
                  gaonirico
                  Mnn, maybe two errors: the first
                  quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
                  ... the second and but notable is that not takes me the changes of parameters in the menu
                  • P
                    Pierreden
                    It seems like Sketchup cant find the correct material, which is "Ivyleaf_2" (it looks for "Ivyleaf_21"), or that vray looks for the wrong one. Does this happen every time you make an ivy, or does it happen on special actions? Cant recreate this myself. After completely uninstaling and reinstaling the plugin, i dont get any errors with sketchup nor with vray
                    http://i.imgur.com/eSwjM.jpg
                    (I appreciate your debugging very much gaonirico!!)
                    • G
                      gaonirico
                      It uninstalled and installed and did not give errors with the material. In the image of the left all parameters are in 1 , in the image of the right all parameters are in 50. There is not significant changes in both cases... I am sorry if do not speak well the english language ^_^
                      • F
                        function
                        I'm handling A LOT more branches in the new version 👍
                        • soloS
                          solo
                          Working for me also.
                          http://www.solos-art.com
                          • thomthomT
                            That is a V-Ray for SketchUp error. What version do you have installed?
                            • massimoM
                              massimo Moderator
                              Thanks for this one Pierreden. 👍 I've tried the very first version and it worked, but now i get this when i start the plugin:
                              Error; #<RuntimeError; Can't insert empty component.>
                              C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load'
                              C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load_definitions'
                              C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;10;in `initialize'
                              C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;348;in `new'
                              C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;347;in `call'
                              Maybe SU 8 is required?
                              • M
                                mukul.ar
                                I don't know if its just me or some other thea user, probably solo can confirm... I get more leaves in thea than the ones visible in sketchup.. this may be a sketchup to thea issue, maybe not.. just thought of sharing it here.
                                My Works
                                • M
                                  mukul.ar
                                  I've uploaded a *Rar file of the sketchup file of the above image. In case anyone wants to look into it... will try and see if its a one off incident or happens again...
                                  great plugin by the way!! 😄
                                  *EDIT: definitely something going on here... the problem persits.. leaves are scattering around in thea. Its probably due to the way the pivot points might be getting relocated or twisted somehow in the sketchup to thea interface or maybe something totally unrelated..
                                  11.rar
                                  My Works
                                  • B
                                    bbx
                                    I also got the
                                    Error: #<RuntimeError: Can't insert empty component.>
                                    Figured out the texture components are in SU8 format, so I converted them to SU7 and it al works fine.
                                    http://www.megaupload.com/?d=2HBVEVR0
                                    Great plugin, thanks a lot!
                                    Dave
                                    • PixeroP
                                      Pixero
                                      I got the same problem in Thea as described above.
                                      Will now use components with "ivyleaf" in the name as leafs. 3 included by default.
                                      May I suggest an option where you select what components should be used as leaves instead.
                                      How is your solution working if you want to use different leaves for different "ivys"?
                                      • M
                                        mukul.ar
                                        @ Pixero: the leaves are materials applied to rectangular components. I believe you can select a new material (your leaf) and change it in one component (will change in all). But it might have limitations as to the position of the texture of the leaves. (or not)
                                        how did you go about solving the thea issue?
                                        My Works
                                        • soloS
                                          solo
                                          Thea users: uncheck 'export as components' before exporting.
                                          Change the leaves in thea, just copy the one you like and paste it in the material slot of the one you want to replace.
                                          • PixeroP
                                            Pixero
                                            Thats just it.
                                            I would like to use
                                            a) different components for different Ivy's.
                                            b) components that are not just a rectangle.
                                            • 6
                                            • 7
                                            • 8
                                            • 36
                                            • 37
                                            • 6 / 37
