    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
    • soloS
      Actually it's a combination of three plugins, e-onlumenrt.rb seems to mess with ivy, ivy and lumenrt mess with JPP, however if I remove lumenrt then ivy and JPP work.... strange.
      • P
        Pierreden
        @66searcher/gaonirico: Thats not good. Uploaded a new fix (0.5.1). test it out.
        @solo: Thats very weird. The only thing i can think of is that LumenRT adds an observer to something. Checked out JPP's source and cant find any sheared namespaces or anything.... Any suggestions?
        • soloS
          It's lumenrt that's the culptrit. no problems now that I deleted it.
          I reported this to them on the e-on software beta forum.
          • G
            gaonirico
            I uninstalled the previous version and installed the update but follows without functioning
            • P
              Pierreden
              Any messages in the ruby console?
              • G
                gaonirico
                Error: #<IOError: Invalid component file>
                C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
                C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
                C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
                • P
                  Pierreden
                  Try the new file (0.5.2) 👍
                  • G
                    gaonirico
                    Yeah, it working fine now... Thanks Pierreden, million thanks
                    • G
                      gaonirico
                      The proof that works well:
                      • G
                        gaonirico
                        Mnn, maybe two errors: the first
                        quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
                        ... the second and but notable is that not takes me the changes of parameters in the menu
                        • P
                          Pierreden
                          It seems like Sketchup cant find the correct material, which is "Ivyleaf_2" (it looks for "Ivyleaf_21"), or that vray looks for the wrong one. Does this happen every time you make an ivy, or does it happen on special actions? Cant recreate this myself. After completely uninstaling and reinstaling the plugin, i dont get any errors with sketchup nor with vray
                          http://i.imgur.com/eSwjM.jpg
                          (I appreciate your debugging very much gaonirico!!)
                          • G
                            gaonirico
                            It uninstalled and installed and did not give errors with the material. In the image of the left all parameters are in 1 , in the image of the right all parameters are in 50. There is not significant changes in both cases... I am sorry if do not speak well the english language ^_^
                            • F
                              function
                              I'm handling A LOT more branches in the new version 👍
                              • soloS
                                Working for me also.
                                  That is a V-Ray for SketchUp error. What version do you have installed?
                                  • massimoM
                                    massimo Moderator
                                    Thanks for this one Pierreden. 👍 I've tried the very first version and it worked, but now i get this when i start the plugin:
                                    Error; #<RuntimeError; Can't insert empty component.>
                                    C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load'
                                    C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load_definitions'
                                    C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;10;in `initialize'
                                    C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;348;in `new'
                                    C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;347;in `call'
                                    Maybe SU 8 is required?
                                      mukul.ar
                                      I don't know if its just me or some other thea user, probably solo can confirm... I get more leaves in thea than the ones visible in sketchup.. this may be a sketchup to thea issue, maybe not.. just thought of sharing it here.
                                      My Works
                                        mukul.ar
                                        I've uploaded a *Rar file of the sketchup file of the above image. In case anyone wants to look into it... will try and see if its a one off incident or happens again...
                                        great plugin by the way!! 😄
                                        *EDIT: definitely something going on here... the problem persits.. leaves are scattering around in thea. Its probably due to the way the pivot points might be getting relocated or twisted somehow in the sketchup to thea interface or maybe something totally unrelated..
                                        11.rar
                                        My Works
                                        • B
                                          bbx
                                          I also got the
                                          Error: #<RuntimeError: Can't insert empty component.>
                                          Figured out the texture components are in SU8 format, so I converted them to SU7 and it al works fine.
                                          http://www.megaupload.com/?d=2HBVEVR0
                                          Great plugin, thanks a lot!
                                          Dave
                                          • PixeroP
                                            Pixero
                                            I got the same problem in Thea as described above.
                                            Will now use components with "ivyleaf" in the name as leafs. 3 included by default.
                                            May I suggest an option where you select what components should be used as leaves instead.
                                            How is your solution working if you want to use different leaves for different "ivys"?
                                            • 36
                                            • 37
                                            • 6 / 37
