    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.1k Views 172 Watching
    • soloS
      Is it just me or does everyone have a problem with JPP now? When I delete the Ivy plugin then JPP works, with Ivy it hangs.
      • 66searcher6
        66searcher
        @Pierreden: 👍
        ...when i select it from plugins sub-menu nothings appear(no menu) & selection(mouse left button) stops working ,and it can't be deactivate from plugins sub-menu.until i select a tool from toolbar..and then it makes it deactivate!
        it's a complicated situation that i can't explain in better way ! 😒
        http://hamidtoliat.deviantart.com/
        • G
          gaonirico
          It happens me the same thing that 66searcher. It can be a conflict with other plugins
          • soloS
            Actually it's a combination of three plugins, e-onlumenrt.rb seems to mess with ivy, ivy and lumenrt mess with JPP, however if I remove lumenrt then ivy and JPP work.... strange.
            • P
              Pierreden
              @66searcher/gaonirico: Thats not good. Uploaded a new fix (0.5.1). test it out.
              @solo: Thats very weird. The only thing i can think of is that LumenRT adds an observer to something. Checked out JPP's source and cant find any sheared namespaces or anything.... Any suggestions?
              • soloS
                It's lumenrt that's the culptrit. no problems now that I deleted it.
                I reported this to them on the e-on software beta forum.
                • G
                  gaonirico
                  I uninstalled the previous version and installed the update but follows without functioning
                  • P
                    Pierreden
                    Any messages in the ruby console?
                    • G
                      gaonirico
                      Error: #<IOError: Invalid component file>
                      C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
                      C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
                      C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
                      • P
                        Pierreden
                        Try the new file (0.5.2) 👍
                        • G
                          gaonirico
                          Yeah, it working fine now... Thanks Pierreden, million thanks
                          • G
                            gaonirico
                            The proof that works well:
                            • G
                              gaonirico
                              Mnn, maybe two errors: the first
                              quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
                              ... the second and but notable is that not takes me the changes of parameters in the menu
                              • P
                                Pierreden
                                It seems like Sketchup cant find the correct material, which is "Ivyleaf_2" (it looks for "Ivyleaf_21"), or that vray looks for the wrong one. Does this happen every time you make an ivy, or does it happen on special actions? Cant recreate this myself. After completely uninstaling and reinstaling the plugin, i dont get any errors with sketchup nor with vray
                                http://i.imgur.com/eSwjM.jpg
                                (I appreciate your debugging very much gaonirico!!)
                                • G
                                  gaonirico
                                  It uninstalled and installed and did not give errors with the material. In the image of the left all parameters are in 1 , in the image of the right all parameters are in 50. There is not significant changes in both cases... I am sorry if do not speak well the english language ^_^
                                  • F
                                    function
                                    I'm handling A LOT more branches in the new version 👍
                                    • soloS
                                      Working for me also.
                                        That is a V-Ray for SketchUp error. What version do you have installed?
                                        • massimoM
                                          massimo Moderator
                                          Thanks for this one Pierreden. 👍 I've tried the very first version and it worked, but now i get this when i start the plugin:
                                          Error; #<RuntimeError; Can't insert empty component.>
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load_definitions'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;10;in `initialize'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;348;in `new'
                                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;347;in `call'
                                          Maybe SU 8 is required?
                                            mukul.ar
                                            I don't know if its just me or some other thea user, probably solo can confirm... I get more leaves in thea than the ones visible in sketchup.. this may be a sketchup to thea issue, maybe not.. just thought of sharing it here.
                                            My Works
                                            • 36
                                            • 37
                                            • 6 / 37
