    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • G
      gaonirico
      Error: #<IOError: Invalid component file>
      C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
      • P
        Pierreden
        Try the new file (0.5.2) 👍
        • G
          gaonirico
          Yeah, it working fine now... Thanks Pierreden, million thanks
          • G
            gaonirico
            The proof that works well:
            • G
              gaonirico
              Mnn, maybe two errors: the first
              quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
              ... the second and but notable is that not takes me the changes of parameters in the menu
              • P
                Pierreden
                It seems like Sketchup cant find the correct material, which is "Ivyleaf_2" (it looks for "Ivyleaf_21"), or that vray looks for the wrong one. Does this happen every time you make an ivy, or does it happen on special actions? Cant recreate this myself. After completely uninstaling and reinstaling the plugin, i dont get any errors with sketchup nor with vray
                http://i.imgur.com/eSwjM.jpg
                (I appreciate your debugging very much gaonirico!!)
                • G
                  gaonirico
                  It uninstalled and installed and did not give errors with the material. In the image of the left all parameters are in 1 , in the image of the right all parameters are in 50. There is not significant changes in both cases... I am sorry if do not speak well the english language ^_^
                  • F
                    function
                    I'm handling A LOT more branches in the new version 👍
                    • soloS
                      Working for me also.
                        That is a V-Ray for SketchUp error. What version do you have installed?
                        • massimoM
                          massimo Moderator
                          Thanks for this one Pierreden. 👍 I've tried the very first version and it worked, but now i get this when i start the plugin:
                          Error; #<RuntimeError; Can't insert empty component.>
                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load'
                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;305;in `load_definitions'
                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;10;in `initialize'
                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;348;in `new'
                          C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb;347;in `call'
                          Maybe SU 8 is required?
                            mukul.ar
                            I don't know if its just me or some other thea user, probably solo can confirm... I get more leaves in thea than the ones visible in sketchup.. this may be a sketchup to thea issue, maybe not.. just thought of sharing it here.
                            My Works
                              mukul.ar
                              I've uploaded a *Rar file of the sketchup file of the above image. In case anyone wants to look into it... will try and see if its a one off incident or happens again...
                              great plugin by the way!! 😄
                              *EDIT: definitely something going on here... the problem persits.. leaves are scattering around in thea. Its probably due to the way the pivot points might be getting relocated or twisted somehow in the sketchup to thea interface or maybe something totally unrelated..
                              11.rar
                              My Works
                              • B
                                bbx
                                I also got the
                                Error: #<RuntimeError: Can't insert empty component.>
                                Figured out the texture components are in SU8 format, so I converted them to SU7 and it al works fine.
                                http://www.megaupload.com/?d=2HBVEVR0
                                Great plugin, thanks a lot!
                                Dave
                                • PixeroP
                                  Pixero
                                  I got the same problem in Thea as described above.
                                  Will now use components with "ivyleaf" in the name as leafs. 3 included by default.
                                  May I suggest an option where you select what components should be used as leaves instead.
                                  How is your solution working if you want to use different leaves for different "ivys"?
                                    mukul.ar
                                    @ Pixero: the leaves are materials applied to rectangular components. I believe you can select a new material (your leaf) and change it in one component (will change in all). But it might have limitations as to the position of the texture of the leaves. (or not)
                                    how did you go about solving the thea issue?
                                    My Works
                                    • soloS
                                      Thea users: uncheck 'export as components' before exporting.
                                      Change the leaves in thea, just copy the one you like and paste it in the material slot of the one you want to replace.
                                      • PixeroP
                                        Pixero
                                        Thats just it.
                                        I would like to use
                                        a) different components for different Ivy's.
                                        b) components that are not just a rectangle.
                                        • P
                                          Pierreden
                                          @pixero said:
                                          Thats just it.
                                          I would like to use
                                          There is no need for the component to be rectangular, theres no limitations at all. All you need to think about is that the component axis is where the leaf attaches to the stem, and that the green axis (y) is the depth, x is the width and z is the height/thickness of the leaf.
                                          http://i.imgur.com/IG8cV.jpg
                                          As i said, beyond this there is no rules or requirements, (unless i forgot about something essential?). The easiest way to make a new leaf is to insert a old leaf component, click "make unique" and alter it as you like
                                          Regarding leaf selection, i guess a less primitive method will come in a future release, but for now you'll have to delete the leafs you dont want on the ivy.... Sorry about that. (Uploaded version 0.5.3 which makes it so that the leaf components are only loaded on startup, not every time the SketchupIvy tool is activated. The components can be found in the "Plugins/LiveIvy/Textures/" folder)
                                          Peace
                                          • 66searcher6
                                            66searcher
                                            @Pierreden:
                                            well done ... 👍 😄
                                            http://hamidtoliat.deviantart.com/
                                            • 36
                                            • 37
                                            • 6 / 37
