    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 146.9k Views 46 Watching
    • fredo6F Offline
      fredo6
      From now on, the information on SUClock is maintained on the Plugin Home Page of SUClock. This is also where you can download the RBZ file.
      • LibFredo6: v14.3b or above
      • Usage: Free
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      SUClock helps you to track the effective time spent in Sketchup. The concept of effective time is based on the activity recorded within a certain duration, called idle time, which is a kind of ‘time to think’ (or the time to have a coffee).
      Time is tracked in a Project, which can group several .skp models. A Project is simply materialized by a file with extension .suclock to which you attach your models.
      SUClock optionally displays a small clock showing the effective time spent in the project which your models are attached to. It also includes some statistics about where the time was spent (by models, by tools, by dates) which can be printed or exported in CSV.
      SUCLock User Manual - English - v1.5 - 27 Nov 2013.pdf
      • KrisidiousK Offline
        Krisidious
        Fredo... as usual... You Rock!
        By: Kristoff Rand
        • EarthMoverE Offline
          EarthMover
          Man, do I need this. Sweet work! This will definitely help with billing. 👍 👍
          Content Creator at Skapeup
            SketchUpNoobie
            AWESOME!!! 😄 This looks like yet another very helpful tool Fredo. 👍 👍
            SketchUpNoobie: the complete noob in all things SketchUp.
              Daniel S
              Thank you Fredo!!! A great tool!!!
              Daniel S
              • Didier BurD Offline
                Didier Bur
                Super comme d'hab, intéressant pour savoir à quoi on passe le plus de temps dans SU...
                DB
                  JuanV.Soler
                  The Time has arrived to become productive 😄
                  you are a master
                  many thanks Fredo
                    Remember people to use the donation button. Fredo deserves it!
                      Krisidious
                      this plugin is awesome... I'm loving it. actually tracks the real time you're modeling, not just how long the program is open. thanks Fredo you Rock!
                      By: Kristoff Rand
                        Krisidious
                        ok I found a problem with this plugin... it's not taking me long enough to model stuff. I'm never going to make any money this way. can you add a double billing option? thanks...
                        By: Kristoff Rand
                        • jeff hammondJ Offline
                          jeff hammond
                          i'm a little bit scared to install it myself 😄
                          dotdotdot
                          • EscapeArtistE Offline
                            EscapeArtist
                            Would it be possible to feature the system clock in the same window?
                            • fredo6F Offline
                              fredo6
                              Do you mean the regular time? The one you have displayed in the Windows task bar.
                              Although there are plenty of clock utilities, I understand that your problem would be to have it visible within the Sketchup main window.
                              It is of course a possibility
                              Fredo
                                EscapeArtist
                                Yes, the one and the same. I use auto-hide for my taskbar so that I have a little more real estate to view SU on, it would be very convenient to have current time and the time used in the same window rather than having to mouse down to the taskbar. Just a thought. If I'm the only one requesting this, don't bother, a truly minor issue.
                                • halroachH Offline
                                  halroach
                                  Great Plugin!
                                  For some reason the clock window comes out cropped on my computer. Can't resize it though maximize works.
                                  Thanks!!
                                  FlexTools - Super Quick Windows, Doors, Slats...
                                    Maybe the inverse will be fun !
                                    Say you have just 10 minutes for make something in Su! 😒
                                    A ring bells when 10 minutes inside SU effective are elapsed! 💚
                                    Surfing internet is of course out of the count! ☀
                                    • fredo6F Offline
                                      fredo6
                                      I know there is a problem, which I need to fix.
                                      Are you on Vista or Windows 7, and which IE browser do you have?
                                      Fred
                                        Ben Ritter
                                        Thank you, again, Fredo.
                                        • halroachH Offline
                                          halroach
                                          Fred
                                          I'm on windows XP 😎
                                          Internet Explorer 8
                                          • JClementsJ Offline
                                            JClements
                                            I do kind of like the idea of an alarm the user can set for the overall project (or maybe even a model file) when X hours has been attained.
                                            It would help to stay within a project's budgeted hours or within a budget hours for phase/task for a project.
                                            John
                                            • 6
                                            • 7
                                            • 1 / 7
