    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 158.5k Views 46 Watching
    • KrisidiousK Offline
      Krisidious
      ok I found a problem with this plugin... it's not taking me long enough to model stuff. I'm never going to make any money this way. can you add a double billing option? thanks...
      By: Kristoff Rand
      • jeff hammondJ Offline
        i'm a little bit scared to install it myself 😄
        • EscapeArtistE Offline
          EscapeArtist
          Would it be possible to feature the system clock in the same window?
          • fredo6F Offline
            Do you mean the regular time? The one you have displayed in the Windows task bar.
            Although there are plenty of clock utilities, I understand that your problem would be to have it visible within the Sketchup main window.
            It is of course a possibility
              EscapeArtist
              Yes, the one and the same. I use auto-hide for my taskbar so that I have a little more real estate to view SU on, it would be very convenient to have current time and the time used in the same window rather than having to mouse down to the taskbar. Just a thought. If I'm the only one requesting this, don't bother, a truly minor issue.
              • halroachH Offline
                halroach
                Great Plugin!
                For some reason the clock window comes out cropped on my computer. Can't resize it though maximize works.
                Thanks!!
                FlexTools - Super Quick Windows, Doors, Slats...
                  Maybe the inverse will be fun !
                  Say you have just 10 minutes for make something in Su! 😒
                  A ring bells when 10 minutes inside SU effective are elapsed! 💚
                  Surfing internet is of course out of the count! ☀
                  • fredo6F Offline
                    I know there is a problem, which I need to fix.
                    Are you on Vista or Windows 7, and which IE browser do you have?
                    Fred
                      Ben Ritter
                      Thank you, again, Fredo.
                      • halroachH Offline
                        halroach
                        Fred
                        I'm on windows XP 😎
                        Internet Explorer 8
                        • JClementsJ Offline
                          JClements
                          I do kind of like the idea of an alarm the user can set for the overall project (or maybe even a model file) when X hours has been attained.
                          It would help to stay within a project's budgeted hours or within a budget hours for phase/task for a project.
                          John
                          • fredo6F Offline
                            John
                            John,
                            Would it be OK if I change the background of the clock (say to Red) to indicate that the time is over the limit (the limit will be set in the dialog box)?
                              JClements
                              A nice idea. What ever is the easiest to implement.
                              Alternative idea. One cirle. Green for well within budgeted hours, Yellow (or blinking yellow) for close maximum budget (ie., 2 hours), Red for over limit.
                              Post Script: When I clicked on a link for donations via PayPal, I got a master page in French and my contribution did not take.
                              • halroachH Offline
                                halroach
                                When exporting to CSV for opening with Excel, Excel doesn't recognize the day dates in their current format which is:
                                "Tue 03 May"
                                I think it recognizes dd.mm.yy or dd.mm.yyyy or dd.mmm.yyyy etc. or with a / - dd/mm/yy or even the backward American way which is mm.dd.yy.
                                Anyone of those formats, preferable the first and second would be great!
                                On the other hand the month column is recognized OK.
                                great great plugin!
                                • halroachH Offline
                                  halroach
                                  If I'm working on several sketchup models at the same time which are all linked to the same project, might there be any time syncing problems?
                                    marne
                                    too bad I've bought "time track" long ago. Thanks for this great script!!!
                                    • fredo6F Offline
                                      In principle, this should work.
                                      I am interested in your feedback however if you find issues. Just remember that activity is tracked on events, not on focus, i.e. when you use interactive SU Tools or scripts.
                                      • fredo6F Offline
                                        NEW RELEASE: SUCLOCK 1.1b - 19 May 11
                                        This small update just adds an extra column with the date formatted in Excel compliant format (dd-mm-yyyyy) for the CSV export of the view by Day/Month. This fixes a problem mentioned by Halroach.
                                        Update is published in main post.
                                        • halroachH Offline
                                          halroach
                                          boy, you're quick!!
                                          nice!
                                            Krisidious
                                            I was wondering what the capabilities were for employees. could this be installed on an employee's computer to track his time? and I know it could. but could it be a protected file? how would you know that no one had edited the file for time tracked? if someone sends me their file will it show the clock on it and how much time has been used?
                                            just thinking outloud... and as I have said before, fantastic plugin Fredo...
                                            By: Kristoff Rand
                                            • 1 / 7
