    How do I reduce the triangle/faces count in a tin?
    7 Posts 4 Posters 4.2k Views 4 Watching
    • B
      bladestar
      Hi good people
      I have a comlex/curved tin with thousands of faces and i would like to reduce the number of triangles/faces as there is way too many that are not needed for the shape involved.
      is this easily possible, is the a tool to do this or must i do it manually?
      Thanks a loit for your help
        In Artisan there is a Polyreducer tool. There is also a free earlier version that is slightly problematic.
        Tgi3D Amorph has a great Downsampling tool that you can use as it's a 30 day trial.
        Or export to another app like Blender and reduce poly count there.
          404 Not Found
          (forums.sketchucation.com)
          You'll find those plugins here
          • J
            Jim
            MeshLab has some good cleanup tools, but it may take some practice to get it right. The work-flow isn't easy either - you need to export the model as .dae, load in MeshLab, process, save, then import back into SketchUp.
            However, MeshLab works remarkably well. Here is an image of a model with reduced polys using MeshLab's "Quadratic Edge Collapse Decimation" filter twice using a 50% reduction.
            http://i.min.us/imGeTK.png
            • M
              mac1
              See this link for thoughts on Mesh Lab https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0BzoOdxbAUZ-WZjcwZDgwYzQtZjdjOS00YWI5LWE1NjctNDQ4ZWIzN2U1MTFm&hl=en&authkey=CJzM55oC.
              It has a huge selection of cleaning, repairing and re-meshing filters. The learning curve is steep( sparse documentation). If at all possible I would used the plugin tools available for SU.
              • B
                bladestar
                taanks a lot guys πŸ˜„
                • B
                  bladestar
                  here's the end result..
                  got the faces down for the whole rifle by about 50% πŸ˜„
                  hope u like it
                  Grip
                  Rifle
                  Back view
                  Site detail
