    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 86.1k Views 46 Watching
      You could rotate 180 and then flip the PNG images using Gimp or PS, before the OBJ import...
      There are batch plugins for Gimp to let you do this, en mass...
      See Gimp's BIMP http://alessandrofrancesconi.it/projects/bimp/
      • F Offline
        fluid
        Just released v.1.0.1 featuring:
        • Units options
        • Flip YZ option
        • Read color and texture from material library
        • Triangulate polygons option
        • Should handle negative indices (not tested)
        Thanks to TIG for the suggestions.
        Check at the end of the page: http://www.fluidimporter.com/downloads
          Rivalz
          When ever I install the new FluidImporter 2 for SketchUp 2015 64bit - OSX my sketchup will crash on start up. Placing the .plugin file in the package contents only causes it crash when I go to select file>import. If anyone has any ideas or more info please let me know.
            jumpjack
            How do I install the plugin without running the executable? I extracted all the files using Uniextract, but now what?
              What's the purpose of not using the .exe?
                jumpjack
                keeping my office pc clean
                • F Offline
                  fluid
                  We just released FluidImporter Pro, which imports the following formats: .obj, .fbx, .stl, .ply, .x, .3ds, .dae, .ase
                  Also the regular FluidImporter has been updated (it's now called FluidImporter Lite).
                  Please check http://www.fluidimporter.com for instruction on how to install and use it.
                  • F Offline
                    fluid
                    We just released FluidImporter 3.1.0. You can get it here.
                    Here's what's new:
                    • Faster import
                    • FluidImporter is now a full .rbz extension, with a single file for Windows/OSX
                    • You can access FluidImporter funtionality through the menu Extensions -> FluidImporter
                    • Added edge smooth option
                    • Options are now saved so you don't lose your settings when closing SkechUp
                    • 6
                    • 7
                    • 8
                    • 9
                    • 9 / 9
