    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 90.5k Views 46 Watching
    • F Offline
      fluid
      Hi Everybody,
      We just released the first beta of FluidImporter, a free, fast .obj importer entirely written in C++.
      For now it supports only the .obj format, other formats will be added in future releases.
      You can grab it from http://www.fluidimporter.com/downloads
      Nicola
      • K Offline
        Khai
        you mean a free Demo of....
        • F Offline
          fluid
          No, FluidImporter is completely free.
          • K Offline
            Khai
            it says
            "Here you can download FluidRay for SketchUp demo. The demo version has all the features of the full version except for a limited resolution. "
            the word DEMO is quite clear.
            • numbthumbN Offline
              numbthumb
              Fluidimporter is completely free, FluidRay renderer can be downloaded as a demo.
              Although it is a bit confusing:
              Anyway, thanks for the heads-up.
              Comfortably numb...
              • K Offline
                Khai
                my bad. the filenames also confused 2 others I showed it to as well. to alike on the same page.
                • F Offline
                  fluid
                  There is a distinction between "FluidImporter" and "FluidRay".
                  FluidImporter is a plugin to import .obj files in SketchUp and is FREE.
                  FluidRay is the physically based renderer, and is in fact available in DEMO version.
                  If you want a FREE .obj importer, just scroll down the download page... http://www.fluidray.com/downloads
                    Thanks for this free compiled OBJ importer; it is potentially a welcome advance on my own free OBJimporter Ruby script, that can be slow and not always successful...
                    I have tested yours against mine and I can now comment as follows...
                    It is very fast. [there's no 'progress-report' - but that's probably because it was so fast?]
                    It makes no attempt to make the object the correct size - i.e. there's no 'units' option. It therefore needs manual scaling after the import.
                    It has no option to flip the object's YZ axes - many OBJ are made with these flipped. It therefore needs manual rotation after import.
                    It does not follow the associated MTL file's settings, and although it makes all of the required materials by name it does not assign RGBA values or textures to them - instead it makes all materials look the same with a 'checker' texture... which is confusing.
                    I appreciate that this is the first version but if it is to be taken seriously I recommend that you address these issues with some urgency...testFluidxxx.PNG
                    • F Offline
                      fluid
                      Hi TIG,
                      Thanks for the suggestions. I'll put them on the top of the list.
                      Nicola
                        This is causing alot of bugsplats for me? On quite simple .obj files.
                          This is causing a lot of bugsplats for me? On quite simple .obj files.
                          And no 'Error 666' πŸ˜‰ [private joke πŸ˜’ ]
                          • F Offline
                            fluid
                            Richard, can you provide the file that causes the crashes?
                              @fluid said:
                              Just released v.1.0.1 featuring:
                              • Units options
                              • Flip YZ option
                              • Read color and texture from material library
                              • Triangulate polygons option
                              • Should handle negative indices (not tested)
                                Thanks to TIG for the suggestions.
                                Check at the end of the page: http://www.fluidray.com/downloads
                              Thanks, couple of issues...
                              Flip YZ Yes 'mirrors' the result too, and it's not placed the same as in the original πŸ˜•
                              The Material Groups Yes/No Option is confusing as it did exactly the opposite what I expected... πŸ˜’Capture.PNG
                              • F Offline
                                fluid
                                Released 1.0.2, should fix the issues...
                                  • P Offline
                                    pibuz
                                    Hi fluid!
                                    Wonderful tool, your obj importer!
                                    ..still, I seldom find some troubles in importing some obj files: most od the times SU reads the textures and UV mapping very well, but sometimes it happens that only ONE material is read from the source obj file, and it is applied to the whole geometry (note: all the faces are correctly UV mapped with the texture of the only material imported).
                                    How come this? Can I fix it?
                                    Thank you a lot!
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                      The OBJ importer tool is in need of at least one last tweak... it isn't reading the materials 'alpha' from the MTL file. For example...
                                      newmtl Translucent_Glass_Gray
                                      Ka 0.000000 0.000000 0.000000
                                      Kd 0.500000 0.500000 0.500000
                                      Ks 0.000000 0.000000 0.000000
                                      d 0.600000
                                      The d value is used as this material's transparency 'alpha' thus - material.alpha=d
                                      • KrisidiousK Offline
                                        Krisidious
                                        I use Tig's .OBJ importer... is there something different about this one? does it allow me to import a glass of beer? cuz I could use one.
                                        By: Kristoff Rand
                                          This new 'compiled' OBJimporter WILL be better than mine - IF he fixes the transparent material issue...
                                          It's faster...
                                          • F Offline
                                            fluid
                                            Hi pibuz, can you provide the file that causes problems?
                                            • 8
                                            • 9
                                            • 1 / 9
