    Roundcorner plugin - 'permission denied' SU8
    12 Posts 8 Posters 1.7k Views 8 Watching
      dcdesign
      I'm unable to access the RoundCorner tool in SU8 with a 'Limited' User account.
      I did not have this issue in SU7 using this same 'Limited' User account.
      Also in contrast, the Curviloft tool opens without issue in SU8 using the same 'Limited' User account.
      If I change the 'Limited' account to an 'Administrator' account the RoundCorner tool opens without issue.
      I tried a new download and overwrite extraction of the RoundCorner tool and LibFredo6.rb just for grins to see if there was any change, but there was none. Also, SU7 has been removed so I know it's being extracted into the SU8 plugin directory.
      I'd rather not have to log in to the 'Administrator' account in order to use the 'RoundCorner' tool.
      Any suggestions or work-arounds would be appreciated.
      Ruby Console output-
      Error: #<Errno::EACCES: Permission denied - C:/Program Files/Google/Google SketchUp 8/Plugins/Fredo6Trace.txt>
      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in open'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in trace6' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:313:in init_palette'
      C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:128:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:42:in new'
      C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:42:in launch' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:33:in action__mapping'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:117:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:117:in launch_action'
      C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb:143:in launch_action' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb:159:in startup'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:672:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:672:in command_invoke'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:654:in build_config_commands' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Traductor.rb:874:in call'
      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Traductor.rb:874:in `add_command'
      • mitcorbM Offline
        mitcorb
        This is news to me that you have to have admin rights to use plugins in any version of Sketchup. Of course, I have admin rights on the computers that I use at work and home.
        Maybe if you post in the Roundcorner plugin thread, someone will pick this up and help you.
          I came across this recently will some uni students.
          Their department version of Sketchup and its Plugins etc are on the PC in a section that they can't change or write to. Obviously as each PC is accessible to anyone with a login it could allow all sorts of messing on with Program files otherwise. This prevented them from using a new script unless their IT guy added it to the Plugins for them... BUT then if the script needed to write stuff to a subfolder it failed too... My fix was to write a short script that the IT guys added to each Plugins folder that added a new folder to Ruby's '$LOAD_PATH' array - H:\Sketchup_Plugins\ and loads the scripts in there [if any] - 'H:' is always the drive-letter assigned to every student at login on a PC. So now if they add that folder and put their scripts in it they'll load too. Provided that the script uses a FILE path to find its subfolders it will use the subfolder in their 'Sketchup_Plugins' folder too. Unfortunately if a script uses find_support_file("Plugins") it will look in the wrong place πŸ˜’
          At least this means that the IT guy only had to make one tweak to the installation and they can mess on with their own scripts knowing they'll load and run OK...
            This is how phpBB forum software works. Sucks indeed but we cannot help. Go to the plugin index page and search with your browser search on that single page.
              Nice introduction there, Bob. πŸ˜’
              • honoluludesktopH Offline
                honoluludesktop
                There is nothing wrong with this board. Problem is the Rude users.
                • Rich O BrienR Online
                  I thinks that's the worst case of PEBKAC I've seen. πŸ˜‰
                  Is it seeing or seen or scene? πŸ˜’
                    Interesting guy. I have just received this email from him.
                    What the FUCK ARE YOU DOING?
                    I was all ready to login and you said I couldn't
                    I then tried your fucking letter game, and I it still wouldn't let me in
                    WHAT THE FUCK ARE YOU DOING?
                    • Alan FraserA Offline
                      Alan Fraser
                      🀣 🀣 🀣 Way to go, Mr. Tact.
                      3D Figures
                        Well, he is not a member any longer... πŸ˜’
                        I have more than 3 Gb emails about 90% of which is from members seeking help during the last 4 years or so. I really try to be helpful and polite even when sometimes their tone sounds to be a bit frustrated. I just could not get myself into that polite manner this time so I rather banned and deleted the guy. 😳
                        Maybe I will regret it but hey, Sunday is coming and my priest is quite forgiving when it comes to confession.
                          Alan Fraser
                          No apologies or second thoughts necessary Csaba. Somebody ought to buy him a copy of Dale Carnegie's "How to Win Friends and Influence People" for Christmas, πŸ˜‰
                          3D Figures
                            Members often forget their login details. I even have a "canned response" for these cases so it would not have been hard NOT to really type anything (polite or rude) but just copy/paste the response with the relevant info. I was just not in the mood this morning. 😎
