    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 375.1k Views 89 Watching
    • Didier BurD
      Didier Bur
      February 13th 2011: Version 1.4.2.: Bug fixes, resizable dialog, directionnal spray
      What's new in v1.4.2.:
      • bug fix with destination layer using the PointTool and SelectedSurfacesTool,
      • bug fix of random rotation not working using the "Selected Surfaces" shape,
      • bug fix of altitude constraints when using the "Selected Faces" shape,
      • new "shape" to drop components at vertices of edges or curves,
      • new "shape" to evenly drop components at divisions of edges,
      • suppressed "OnMouseLeave" function that caused the tools to exit when the mouse left the graphic window,
      • dropping components on other components with the point shape is now possible,
      • localization files available (German, Danish, French, Portuguese, English, and Spanish as the base set)
      • settings to customize the dialog box behaviour (useful for low res screens),
      • experimental directional spray tool, so you can populate walls with ivy for instance.
      Thanks to the translators: K.F. Blom Balleby, aka Frederik, K. Hauser, aka Charly, E. Mahfuz, Edson, Oxer, Oscar...
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
      PLEASE UNINSTALL PREVIOUS VERSION ON YOUR SYSTEM, IF ANY.
      Earlier versions are downloadable here:http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=76
      Dialog settings
      [attachment=1:3tsuvlco]<!-- ia1 -->tbar.jpg[/attachment
      [attachment=0]spanish_dialog.jpg<!-- ia1 -->[/attachment:3tsuvlco]
      Enjoy, and feel free to report bugs...
      Toolbar
      Example of dialog in spanish
      DB
      • thomthomT
        Great start for 2011!
        btw - v1.3 is now obsolete, right? Could you make a note of that in the post for that version - with a link to this. Having multiple versions around makes trouble for users who stumble upon plugins without the knowledge of what's current. ComponentSpray is a very popular plugin and there will be many links around the internet that leads to the v1.3 version thread.
        • Didier BurD
          Didier Bur
          Good point TT, done.
          DB
          • D
            diegog321
            thank you very much!
            Will certainly try and give feedback
            • FrederikF
              Frederik
              Ooohhh... Looks great, Didier...
              Thanks... 👍
              Cheers
              Kim Frederik
              • Didier BurD
                Didier Bur
                Simon,
                C'est pas clair çà ???
                Nouvelle version 1.4, ancienne 1.3 obsolete, plus de fichiers, plus de lien.
                DB
                • simon le bonS
                  simon le bon
                  Hi !
                  5 minutes try: I love it...
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thDBCompSpray14.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thDBCompSpray14b.jpg
                  *s
                  • simon le bonS
                    simon le bon
                    OOps! Sorry Didier!
                    I was watching this link I had bookmarked: [Plugin] Component Spray update
                    instead of watching on the main Plugin thread: [Plugin] Component Spray Tool 1.3.
                    Those various links also "Spray" the doubt 😆
                    ++simon
                    • simon le bonS
                      simon le bon
                      Dear Didier,
                      Thank you so much.
                      I'm excited to play with this new one.
                      The better presentation I know about Compo Spray was done by takesh h on PushPullbar
                      Here is a link to his first picture:
                      http://www.pushpullbar.com/forums/attachment.php?attachmentid=54035&stc=1&d=1245214267
                      I hope he is going to do the same for your new version.
                      @thomthom said:
                      btw - v1.3 is now obsolete, right? Could you make a note of that in the post for that version - with a link to this...
                      Well 😕 😕 It is still not very clear IMO
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DBCompSpray-1.jpg
                      Cheers, simon.
                      • GaieusG
                        Tanks a lot for the update, Didier! I can hardly wait to test it in "hot" action!
                        • R
                          rv1974
                          Thank you Didier!
                          Please take a look at attached.
                          The only mode is working is 'point'.
                          P.S. And sorry if it was disscussed earlier but but this tool would greatly benefit if one could:
                          1/ work with preselected set of components;
                          2/ spray on component surfaces;
                          3/ spray on surfaces placed one above another (example: to spray entourage upnon balconies stacked in a column)
                          spray.skp
                          • thomthomT
                            +1
                            +1
                            • H
                              hebeijianke
                              THX
                              But It does not work in my PC
                              I know why it does not work
                              I use it in sketchup8.0
                              It works well in sketchup7.1
                              • TIGT
                                @hebeijianke said:
                                THX
                                I [don't] know why it does not work
                                Have you double checked the files are all extracted into the correct Plugin folder/subfolder as directed... AND removed the earlier versions ?
                                Error messages in Ruby Console??
                                • thomthomT
                                  @hebeijianke said:
                                  THX
                                  Can you explain what doesn't work?
                                  Do you get errors?
                                  Are you missing menus?
                                  I use SketchUp8 - works for me.
                                  Didier:
                                  Instead of a modal window to set the preferences before you spray, how about leaving the window open so one can adjust the settings while you work?
                                  (Also: under OSX Webdialogs aren't true modal - they don't act like they do on Windows.)
                                  (The scrollbars in the webdialog should do away if do add body { overflow: hidden; } to the CSS. (or was it to the html element...? I think that might depend if you're using a strict doctype or not.)
                                  • thomthomT
                                    I tried to use the Spray feature - clicked on a face and I was warned it'd create 3000 instances. (I had selected a 1x1x1m cube)
                                    I said Cancel to abort the operation - the Ruby Console output:
                                    Error: #<LocalJumpError: unexpected break> (eval):2544:incs_warning'
                                    (eval):2088:in cs_n_points' (eval):1560:in create_geometry'
                                    (eval):1488:in onLButtonDown'
                                    • thomthomT
                                      @didier bur said:
                                      Simon,
                                      [attachment=0:mz8opdge]<!-- ia0 -->cs13.jpg<!-- ia0 -->[/attachment:mz8opdge]
                                      Would be good to have a redirect there as well.
                                      • FrederikF
                                        Frederik
                                        I also have trouble making this work with SU 8... 😐
                                        Cheers
                                        Kim Frederik
                                        • thomthomT
                                          Like I asked hebeijianke: what specifically is the problem?
                                          It's hard to debug an issue without knowing what the symptoms are.
                                          Exactly what doesn't work as expected and what was expected results/behaviour?
                                          • J
                                            j_forrester
                                            Not sure if i'm having much luck with 1.4 version either. I'm using Sketchup Pro 6. The old 1.3 version worked great.
                                            Everytime I go to run the script, I select my component to spray, selected faces to spray onto. Other options left alone.
                                            I get a dialoge box saying "1000 trials to drop components done. Continue?". At this point it shows 1% complete on the taskbar, I click continue and get a dailoge "more than 2 minutes remaining to complete. Continue?" as soon as I click I get "more than 4 minutes remaining to complete. Continue?" and so on.... never actually creating any copies, just doubling the time with each click?
                                            • 13
                                            • 14
                                            • 1 / 14
