    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 368.5k Views 89 Watching
      rv1974
      Thank you Didier!
      Please take a look at attached.
      The only mode is working is 'point'.
      P.S. And sorry if it was disscussed earlier but but this tool would greatly benefit if one could:
      1/ work with preselected set of components;
      2/ spray on component surfaces;
      3/ spray on surfaces placed one above another (example: to spray entourage upnon balconies stacked in a column)
      spray.skp
        +1
        +1
        • H
          hebeijianke
          THX
          But It does not work in my PC
          I know why it does not work
          I use it in sketchup8.0
          It works well in sketchup7.1
            @hebeijianke said:
            THX
            I [don't] know why it does not work
            Have you double checked the files are all extracted into the correct Plugin folder/subfolder as directed... AND removed the earlier versions ?
            Error messages in Ruby Console??
              @hebeijianke said:
              THX
              Can you explain what doesn't work?
              Do you get errors?
              Are you missing menus?
              I use SketchUp8 - works for me.
              Didier:
              Instead of a modal window to set the preferences before you spray, how about leaving the window open so one can adjust the settings while you work?
              (Also: under OSX Webdialogs aren't true modal - they don't act like they do on Windows.)
              (The scrollbars in the webdialog should do away if do add body { overflow: hidden; } to the CSS. (or was it to the html element...? I think that might depend if you're using a strict doctype or not.)
                I tried to use the Spray feature - clicked on a face and I was warned it'd create 3000 instances. (I had selected a 1x1x1m cube)
                I said Cancel to abort the operation - the Ruby Console output:
                Error: #<LocalJumpError: unexpected break> (eval):2544:incs_warning'
                (eval):2088:in cs_n_points' (eval):1560:in create_geometry'
                (eval):1488:in onLButtonDown'
                  @didier bur said:
                  Simon,
                  C'est pas clair çà ???
                  Nouvelle version 1.4, ancienne 1.3 obsolete, plus de fichiers, plus de lien.
                  [attachment=0:mz8opdge]<!-- ia0 -->cs13.jpg<!-- ia0 -->[/attachment:mz8opdge]
                  Would be good to have a redirect there as well.
                  • FrederikF
                    Frederik
                    I also have trouble making this work with SU 8... 😐
                    Cheers
                    Kim Frederik
                      Like I asked hebeijianke: what specifically is the problem?
                      It's hard to debug an issue without knowing what the symptoms are.
                      Exactly what doesn't work as expected and what was expected results/behaviour?
                        j_forrester
                        Not sure if i'm having much luck with 1.4 version either. I'm using Sketchup Pro 6. The old 1.3 version worked great.
                        Everytime I go to run the script, I select my component to spray, selected faces to spray onto. Other options left alone.
                        I get a dialoge box saying "1000 trials to drop components done. Continue?". At this point it shows 1% complete on the taskbar, I click continue and get a dailoge "more than 2 minutes remaining to complete. Continue?" as soon as I click I get "more than 4 minutes remaining to complete. Continue?" and so on.... never actually creating any copies, just doubling the time with each click?
                        • Didier BurD
                          Didier Bur
                          I get a dialoge box saying "1000 trials to drop components done. Continue?". And so on...
                          This dialog pops up when there are too much constraints (you drew your shape where there is no face that belongs to the layer mask for instance) and the script tries and tries to drop components and cannot.
                          This may be the cause of the problem. Check if your options are consistent.
                          @TT : done.
                          done too (fixed the bug).
                          I tried that but no luck (CSS is greek to me 😳 )
                          I'd like to get rid of that horizontal scrollbar too...
                          I've found a way to use dialog.show{} instead of show_modal{} 😛
                          Keep the bugs comin', I'll fix 'em and publish a patch then.
                          DB
                          • H
                            hebeijianke
                            Error: #<TypeError: can't convert Array into Float>
                            (eval):1752:in raytest' (eval):1752:in raytestH'
                            (eval):2323:in cs_random_points' (eval):1160:in create_geometry'
                            (eval):1052:in onLButtonDown' (eval):1752 Error: #<TypeError: can't convert Array into Float> (eval):1752:in raytest'
                            (eval):1752:in raytestH' (eval):2323:in cs_random_points'
                            (eval):1160:in create_geometry' (eval):1064:in onLButtonUp'
                            (eval):1752
                              @didier bur said:
                              @TT : done.
                              Because you used a strict doctype the HTML DOM acts a bit different. When I applied the rule to the HTML element it worked:
                              <span class="syntaxdefault"><br />html </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">  overflow</span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> hidden</span><span class="syntaxkeyword">;<br />}<br /></span><span class="syntaxdefault"> </span>
                              I think that you can get rid of the inset frame if you set the scrollable argument to false when you create the WebDialog.
                              • Didier BurD
                                Didier Bur
                                Hi folks,
                                Just a note to keep the thread on top of stack...
                                Update 1.4.1. of CompoSpray is available here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=76
                                Mainly bug fixes, backward compatibility, non-modal dialog BUT a true "Ignore hidden geometry" option (thanks to ThomThom): spray can now ignore entities that are masked OR on invisible layers.
                                Next step: a directionnal spray 🎉
                                DB
                                • X
                                  xrok1
                                  this is a sweet update. 😍
                                  do you have an explanation of how to use the layer mask? 😳
                                  • Didier BurD
                                    Didier Bur
                                    Select a layer in the dropdown list and components will "fall" only on that layer...
                                    DB
                                      Aldob
                                      Thanks,
                                      My SU 7.1 just closing down as soon as I press component spray button on toolbar.
                                      I deleted older version from Plugins folder and my system is Win XP 64
                                      Regards
                                      • Didier BurD
                                        Didier Bur
                                        It does bugsplat ?
                                        DB
                                        • pep75P
                                          pep75
                                          It looks very promising, but it does nothing. I can see the menu etc, but when I push the "spray" button; "the computer says: "No".... 😉
                                          Oh I'm working with v8!
                                          • F
                                            fjb80
                                            The compospray icon shows up, as does the toolbar, but when I click it nothing happens. Here's my error message from the ruby console:
                                            Error: #<Errno::ENOENT: No such file or directory - /Users/Fraser/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/CompoSpray/csSettings.html>
                                            (eval):269:in initialize' (eval):269:in new'
                                            (eval):269:in write_cs_dialog' (eval):107:in compoSpray_main'
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/compoSprayToolbar.rb:14
                                            (eval):269:in `call'
                                            (eval):269
                                            So it looks like it's missing an html file?
                                            Using OS 10.6, SU 8
                                            Thanks,
                                            • 13
                                            • 14
                                            • 1 / 14
