    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 310.9k Views 89 Watching
    • Didier BurD Offline
      Didier Bur
      February 13th 2011: Version 1.4.2.: Bug fixes, resizable dialog, directionnal spray
      What's new in v1.4.2.:
      • bug fix with destination layer using the PointTool and SelectedSurfacesTool,
      • bug fix of random rotation not working using the "Selected Surfaces" shape,
      • bug fix of altitude constraints when using the "Selected Faces" shape,
      • new "shape" to drop components at vertices of edges or curves,
      • new "shape" to evenly drop components at divisions of edges,
      • suppressed "OnMouseLeave" function that caused the tools to exit when the mouse left the graphic window,
      • dropping components on other components with the point shape is now possible,
      • localization files available (German, Danish, French, Portuguese, English, and Spanish as the base set)
      • settings to customize the dialog box behaviour (useful for low res screens),
      • experimental directional spray tool, so you can populate walls with ivy for instance.
      Thanks to the translators: K.F. Blom Balleby, aka Frederik, K. Hauser, aka Charly, E. Mahfuz, Edson, Oxer, Oscar...
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
      PLEASE UNINSTALL PREVIOUS VERSION ON YOUR SYSTEM, IF ANY.
      Earlier versions are downloadable here:http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=76
      Dialog settings
      [attachment=1:3tsuvlco]<!-- ia1 -->tbar.jpg[/attachment
      [attachment=0]spanish_dialog.jpg<!-- ia1 -->[/attachment:3tsuvlco]
      Enjoy, and feel free to report bugs...
      Toolbar
      Example of dialog in spanish
      DB
        Great start for 2011!
        btw - v1.3 is now obsolete, right? Could you make a note of that in the post for that version - with a link to this. Having multiple versions around makes trouble for users who stumble upon plugins without the knowledge of what's current. ComponentSpray is a very popular plugin and there will be many links around the internet that leads to the v1.3 version thread.
          Didier Bur
          Good point TT, done.
          DB
            diegog321
            thank you very much!
            Will certainly try and give feedback
            • FrederikF Offline
              Frederik
              Ooohhh... Looks great, Didier...
              Thanks... 👍
              Cheers
              Kim Frederik
                Didier Bur
                Simon,
                C'est pas clair çà ???
                Nouvelle version 1.4, ancienne 1.3 obsolete, plus de fichiers, plus de lien.
                DB
                • simon le bonS Offline
                  simon le bon
                  Hi !
                  5 minutes try: I love it...
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thDBCompSpray14.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thDBCompSpray14b.jpg
                  *s
                    simon le bon
                    OOps! Sorry Didier!
                    I was watching this link I had bookmarked: [Plugin] Component Spray update
                    instead of watching on the main Plugin thread: [Plugin] Component Spray Tool 1.3.
                    Those various links also "Spray" the doubt 😆
                    ++simon
                      simon le bon
                      Dear Didier,
                      Thank you so much.
                      I'm excited to play with this new one.
                      The better presentation I know about Compo Spray was done by takesh h on PushPullbar
                      Here is a link to his first picture:
                      http://www.pushpullbar.com/forums/attachment.php?attachmentid=54035&stc=1&d=1245214267
                      I hope he is going to do the same for your new version.
                      @thomthom said:
                      btw - v1.3 is now obsolete, right? Could you make a note of that in the post for that version - with a link to this...
                      Well 😕 😕 It is still not very clear IMO
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DBCompSpray-1.jpg
                      Cheers, simon.
                        Tanks a lot for the update, Didier! I can hardly wait to test it in "hot" action!
                          rv1974
                          Thank you Didier!
                          Please take a look at attached.
                          The only mode is working is 'point'.
                          P.S. And sorry if it was disscussed earlier but but this tool would greatly benefit if one could:
                          1/ work with preselected set of components;
                          2/ spray on component surfaces;
                          3/ spray on surfaces placed one above another (example: to spray entourage upnon balconies stacked in a column)
                          spray.skp
                            +1
                            +1
                            • H Offline
                              hebeijianke
                              THX
                              But It does not work in my PC
                              I know why it does not work
                              I use it in sketchup8.0
                              It works well in sketchup7.1
                                @hebeijianke said:
                                THX
                                I [don't] know why it does not work
                                Have you double checked the files are all extracted into the correct Plugin folder/subfolder as directed... AND removed the earlier versions ?
                                Error messages in Ruby Console??
                                  @hebeijianke said:
                                  THX
                                  Can you explain what doesn't work?
                                  Do you get errors?
                                  Are you missing menus?
                                  I use SketchUp8 - works for me.
                                  Didier:
                                  Instead of a modal window to set the preferences before you spray, how about leaving the window open so one can adjust the settings while you work?
                                  (Also: under OSX Webdialogs aren't true modal - they don't act like they do on Windows.)
                                  (The scrollbars in the webdialog should do away if do add body { overflow: hidden; } to the CSS. (or was it to the html element...? I think that might depend if you're using a strict doctype or not.)
                                    I tried to use the Spray feature - clicked on a face and I was warned it'd create 3000 instances. (I had selected a 1x1x1m cube)
                                    I said Cancel to abort the operation - the Ruby Console output:
                                    Error: #<LocalJumpError: unexpected break> (eval):2544:incs_warning'
                                    (eval):2088:in cs_n_points' (eval):1560:in create_geometry'
                                    (eval):1488:in onLButtonDown'
                                      @didier bur said:
                                      Simon,
                                      [attachment=0:mz8opdge]<!-- ia0 -->cs13.jpg<!-- ia0 -->[/attachment:mz8opdge]
                                      Would be good to have a redirect there as well.
                                      • FrederikF Offline
                                        Frederik
                                        I also have trouble making this work with SU 8... 😐
                                        Cheers
                                        Kim Frederik
                                          Like I asked hebeijianke: what specifically is the problem?
                                          It's hard to debug an issue without knowing what the symptoms are.
                                          Exactly what doesn't work as expected and what was expected results/behaviour?
                                            j_forrester
                                            Not sure if i'm having much luck with 1.4 version either. I'm using Sketchup Pro 6. The old 1.3 version worked great.
                                            Everytime I go to run the script, I select my component to spray, selected faces to spray onto. Other options left alone.
                                            I get a dialoge box saying "1000 trials to drop components done. Continue?". At this point it shows 1% complete on the taskbar, I click continue and get a dailoge "more than 2 minutes remaining to complete. Continue?" as soon as I click I get "more than 4 minutes remaining to complete. Continue?" and so on.... never actually creating any copies, just doubling the time with each click?
                                            • 13
                                            • 14
                                            • 1 / 14
